Home » Eclipse Projects » Eclipse Process Manager (Stardust) » SessionContextListener not found, when deploying ipp-portal.war
SessionContextListener not found, when deploying ipp-portal.war [message #954589] Tue, 23 October 2012 01:13
Florian Kammermann is currently offline Florian Kammermann
When I deploy the ipp-portal.war into the JBoss 5.1.0 I have the following Error:
java.lang.ClassNotFoundException: org.eclipse.stardust.ui.web.viewscommon.common.listener.SessionContextListener
As workaround I removed the listener from the WEB-INF/web.xml
Previous Topic:Unable to deploy stardust in weblogic 10.3.3
Next Topic:IceFaces PhaseListener incompatibility, when deploying the ipp-portal.war
Current Time: Sun May 19 05:10:14 EDT 2013
Powered by FUDForum. Page generated in 0.01403 seconds
