| 'atexit' error when upgrading to xdctools 3.16 [message #630417] |
Fri, 01 October 2010 21:24  |
sgspecker Messages: 8 Registered: July 2009 |
Junior Member |
I'm having trouble building a simple hello world C program (app.x86U) that uses the System_printf() function from xdc.runtime.System. The program builds fine under xdctools 3.15.xx, but fails under 3.16.xx and 3.20.xx. (The host environment is Ubuntu 10.04.)
The error reads: System.c:(.text+0x8ec): undefined reference to `atexit'
There's also a warning about "linker.cmd contains output sections; did you forget -T?", but I'm not sure if this is the cause, or what it's really telling me to do.
This seems like a migration issue, but I can't seem to find any suggestions or warnings in the release notes.
The program is about as simple as it gets. A single call to System_printf(). It doesn't even use any arguments.
I dislike attaching long strings to emails, but I'm copying the full make listing in case it helps to decipher the problem.
Scott
making package.mak (because of package.bld) ...
generating interfaces for package app_cfg (because package/package.xdc.inc is older than package.xdc) ...
configuring app_cfg.x86U from package/cfg/app_cfg_x86U.cfg ...
cl86U package/cfg/app_cfg_x86U.c ...
Configuro has completed; it's results are in app_cfg
/usr/bin/gcc -g -I" /home/user/ti-dvsdk_omap3530-evm_4_00_00_17/xdctools_3_16_03 _36/packages " -I" /home/user/ti-dvsdk_omap3530-evm_4_00_00_17/xdctools_3_16_03 _36/packages " -I"/home/user/omap/soln05c_x86_configuro/app/app_cfg/.." -isystem /usr/include -isystem /usr/lib/gcc/i486-linux-gnu/4.4.3/include -Dxdc_target_types__="gnu/targets/std.h" -Dxdc_target_name__=Linux86 -Dxdc_cfg__header__=" /home/user/omap/soln05c_x86_configuro/app/app_cfg/package/cf g/app_cfg_x86U.h " -c app.c -o app.o
/usr/bin/gcc -g -lstdc++ app.o app_cfg/linker.cmd -o app.x86U
/usr/bin/ld: warning: app_cfg/linker.cmd contains output sections; did you forget -T?
/home/user/ti-dvsdk_omap3530-evm_4_00_00_17/xdctools_3_16_03 _36/packages/gnu/targets/rts86U/lib/gnu.targets.rts86U.a86U( System.o86U): In function `xdc_runtime_System_Module_startup(void)':
collect2: ld returned 1 exit status
make: *** [app.x86U] Error 1
| Re: 'atexit' error when upgrading to xdctools 3.16 [message #754690 is a reply to message #630420] |
Thu, 03 November 2011 16:52   |
alan Messages: 2 Registered: November 2011 |
Junior Member |
hello
i'm having the same problem as you, you mentioned that the workaround did the trick, but i don't have clear how you modify the file linkcmd.xdt i'm positng the way mi file looks, hopefully you can tell where to modify it, since i know this it's an old post, thanks in advance
* Copyright (c) 2008 Texas Instruments and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* eclipse.org/legal/epl-v10.html
* Contributors:
* Texas Instruments - initial implementation
/* Linker templates are passed the following arguments:
* $out - an open file stream for the generated linker
* command file
* $args[] - array of zero or more libraries that should be linked
* with (in the order they appear in the argument list)
* We can't add "'s around names; otherwise the GNU linker looks for names
* with "'s.
* The GNU linker accepts any text file as "command files", so there is no
* need to use a special option to identify them. In fact, if you use the
* -T option you must also include the default linker command file (which
* defines the memory map, sections, etc). By not using -T, this command
* file "accumulates" with the default.
/* get the GNU compiler version from the version number returned by ITarget */
var VERSION = this.build.target.version.split(',')[2] - 0;
/* guess(!) the default leading prefix convention for this compiler */
var PREFIX = this.build.target.os == "Windows" ? "_" : "";
/* this file was generated by linkcmd.xdt from the gnu.targets package */
/* function aliases */
%if (prog.build.profile.match(/blas/) == null) {
% for (var keys = this.$$aliases.keys(); keys.hasMoreElements(); ) {
% var key = keys.nextElement();
`PREFIX + key` = `PREFIX + this.$$aliases.get(key)`;
%if ($args.length > 0) {
/* input libraries */
INPUT(
%for (var i = 0; i < $args.length; i++) {
"`$args[i]`"
%var _utils = xdc.loadCapsule("gnu/targets/linkUtils.xs");
%/* Mingw compilers do not work with the SECTIONS directive.
%if (prog.build.target.$name != "gnu.targets.Mingw") {
SECTIONS {
`_utils.genSections(prog)`
%if (xdc.om['xdc.runtime.Text'].isLoaded != true) {
ASSERT(ADDR(xdc.noload) + SIZEOF(xdc.noload) < ADDR(.rodata)
|| ADDR(.rodata) + SIZEOF(.rodata) < ADDR(xdc.noload),
"Sections .rodata and xdc.noload overlap. See xdc.runtime.Text.isLoaded for more.")
%} // end of the workaround for Mingw
* @(#) gnu.targets; 1, 0, 1,370; 11-25-2009 10:23:05; /db/atree/library/trees/xdctargets/xdctargets-b28x/src/
FUDForum. Page generated in 0.01810 seconds
