Home » Language IDEs » CDT » Please help: On Slackware, CDT does not give GNU tool chain choice
icon4.gif  Please help: On Slackware, CDT does not give GNU tool chain choice [message #941249] Fri, 12 October 2012 06:34 Go to next message
Howard Guo is currently offline Howard Guo
Hello!
I am using Slackware 14 and installed the lastest Juno and CDT, like I usually did on other distros. I used to get GNU toolchain available straight away after CDT is installed, however it apparently isn't working on Slackware 14... After installed CDT, there is no "GCC toolchain" available to choose when I create a project.
I have also tried to install GCC cross compile support (from CDT), but there is still no tool chain to choose.
I have been a regular user of CDT but this issue has never happened on me before. Apparently it is specific to Slackware 14?
There is a screenshot attached to this post.
Please offer your suggestiosn Smile thank you
[Updated on: Fri, 12 October 2012 06:36]
Report message to a moderator
Re: Please help: On Slackware, CDT does not give GNU tool chain choice [message #954009 is a reply to message #941249] Mon, 22 October 2012 14:14 Go to previous message
Albert Cheng is currently offline Albert Cheng
Hello Howard,
Have you found solution for your issue? I have a similar issue as described in topic of "Have you found resolution".
Previous Topic:Problem with right-click behaviour
Next Topic:Using Eclipse CDT together with ORACLE PROC
Current Time: Sun May 26 03:45:51 EDT 2013
Powered by FUDForum. Page generated in 0.07458 seconds
