| Problems after upgrading to Spring 3.1.2 [message #953608] |
Mon, 22 October 2012 07:40  |
Thorsten Schlathölter Messages: 179 Registered: February 2012 Location: Düsseldorf |
I tried to upgrade the user region of Virgo 3.5.0 from Springframework 3.0.5 to version 3.1.2.
I followed the following FAQ:
http://wiki.eclipse.org/Virgo/FAQ#How_can_I_change_the_version_of_Spring_framework_in_the_user_region.3F
The problem is now that I get the following error when my plan is loaded:
[2012-10-22 12:28:11.428] ERROR start-signalling-5 org.apache.catalina.startup.ContextConfig The ServletContentInitializer [org.springframework.web.SpringServletContainerInitializer] could not be created java.lang.ClassNotFoundException: org.springframework.web.SpringServletContainerInitializer
at org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:307)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:247)
at org.apache.catalina.startup.ContextConfig.getServletContainerInitializer(ContextConfig.java:1601)
at org.apache.catalina.startup.ContextConfig.processServletContainerInitializers(ContextConfig.java:1519)
at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1222)
at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:855)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:345)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5161)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:895)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:871)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:95)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
SpringServletContainerInitializer is part of the org.springframework.web bundle which is available in version 3.1.2 in ext. I have no idea what might cause the problem. Same plan works fine with the original virgo (with Springframework 3.0.5)
Any hint would be appreciated.
Thorsten
FUDForum. Page generated in 0.01553 seconds
