Home » Eclipse Projects » scout » jdbc connection bundle SqlServer Jtds Drive(help: jdbc connection bundle SqlServer Jtds Drive)
jdbc connection bundle SqlServer Jtds Drive [message #952567] Sun, 21 October 2012 11:25 Go to next message
Diogo Duarte is currently offline Diogo Duarte
Hi everyone:
I'm new to Scout and also to OSGI. I tried to folow the tutorial in the wiki: Write_a_jdbc_connection_bundle but using jTDS driver:
Created a plugin project with java src : org.eclipse.scout.rt.jdbc.jtds125 with a generated Activator
created a lib folder and placed the jTDS jar:jtds-1.2.5.jar
Created 2 packages:
org.eclipse.scout.rt.services.common.jdbc
org.eclipse.scout.rt.services.common.jdbc.style
placed the folowing classes respectivly:
package org.eclipse.scout.rt.services.common.jdbc;
import org.eclipse.scout.rt.server.services.common.jdbc.AbstractSqlService;
import org.eclipse.scout.rt.server.services.common.jdbc.style.ISqlStyle;
import org.eclipse.scout.rt.services.common.jdbc.style.JtdsSqlStyle;
public class AbstractJtdsSqlService  extends AbstractSqlService {
	  protected String getConfiguredJdbcDriverName() {
	    return "net.sourceforge.jtds.jdbc.Driver";
	  protected String getConfiguredJdbcMappingName() {
	    return "jdbc:jtds:<server_type>://<server>[:<port>][/<database>]";
	  protected Class<? extends ISqlStyle> getConfiguredSqlStyle() {
	    return JtdsSqlStyle.class;
and:
package org.eclipse.scout.rt.services.common.jdbc.style;
import java.sql.Connection;
import java.sql.SQLException;
import java.sql.Statement;
import org.eclipse.scout.rt.server.services.common.jdbc.style.AbstractSqlStyle;
public class JtdsSqlStyle extends AbstractSqlStyle {
	private static final long serialVersionUID = -6139827987362401678L;
	public String getConcatOp() {
		return "+";
	public String getLikeWildcard() {
		return "%";
	protected int getMaxListSize() {
		return 1000;
	public boolean isLargeString(String s) {
		return (s.length() > 4000);
	public boolean isBlobEnabled() {
		return true;
	public boolean isClobEnabled() {
		return true;
	public String createDateTimeIsNow(String attribute) {
		return "TRUNC(" + attribute + ", 'MI')=TRUNC(SYSDATE, 'MI')";
	public String createDateTimeIsNotNow(String attribute) {
		return "TRUNC(" + attribute + ", 'MI')!=TRUNC(SYSDATE, 'MI')";
	public void testConnection(Connection conn) throws SQLException {
		Statement testStatement = null;
		try {
			testStatement = conn.createStatement();
			testStatement.execute("SELECT count(1) FROM dbo.sysobjects");
		} finally {
			if (testStatement != null)
				try {
					testStatement.close();
				} catch (Throwable t) {
then exported the 2 packages and added the jar to classpath.
The MANIFEST file is:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Jtds125
Bundle-SymbolicName: org.eclipse.scout.rt.jdbc.jtds125;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Vendor: Diogo Duarte
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Bundle-ClassPath: lib/jtds-1.2.5.jar
Require-Bundle: org.eclipse.scout.rt.server;bundle-version="3.7.0",
 org.eclipse.core.runtime;bundle-version="3.5.0"
Eclipse-RegisterBuddy: org.eclipse.scout.rt.server,pt.diogoduarte.wforce.server
Export-Package: net.sourceforge.jtds.jdbc,
 net.sourceforge.jtds.jdbc.cache,
 net.sourceforge.jtds.jdbcx,
 net.sourceforge.jtds.jdbcx.proxy,
 net.sourceforge.jtds.ssl,
 net.sourceforge.jtds.util,
 org.eclipse.scout.rt.services.common.jdbc,
Bundle-Activator: org.eclipse.scout.jdbc.jtds125.Activator
Bundle-ActivationPolicy: lazy
Afterwards i opened the server package in my ScoutProject and added my plugin to the dependencies:
Require-Bundle: org.eclipse.core.runtime,
 pt.diogoduarte.wforce.shared,
 org.eclipse.scout.http.servletfilter,
 org.eclipse.equinox.http.registry,
I created a
package pt.diogoduarte.wforce.server.services.common.sql;
import org.eclipse.scout.commons.annotations.ConfigOperation;
import org.eclipse.scout.commons.annotations.Order;
import org.eclipse.scout.commons.exception.ProcessingException;
import org.eclipse.scout.rt.services.common.jdbc.AbstractJtdsSqlService;
import org.eclipse.scout.service.IService2;
public class TesteSqlService extends AbstractJtdsSqlService implements IService2 {
    return "jdbc:jtds:sqlserver://sqlserver.scoprolumba.pt:1433/erpscopro";
  protected String getConfiguredPassword() {
    return "xxxx";
  protected String getConfiguredUsername() {
    return "sa";
Then binded to a PageTable throw a StandardOutlineService
and a getContacts() method:
but when i run the server and client get the folowing message in the server log:
!ENTRY org.eclipse.scout.service 4 0 2012-10-21 16:23:39.045
!MESSAGE org.eclipse.scout.service.internal.ServicesExtensionManager.added(ServicesExtensionManager.java:195) register service: bundle=pt.diogoduarte.wforce.server, service=pt.diogoduarte.wforce.server.services.common.sql.TesteSqlService
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/scout/rt/services/common/jdbc/AbstractJtdsSqlService
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:632)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:607)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:568)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.scout.service.internal.ServicesExtensionManager.added(ServicesExtensionManager.java:105)
at org.eclipse.scout.commons.runtime.ExtensionPointTracker.open(ExtensionPointTracker.java:112)
at org.eclipse.scout.service.internal.ServicesExtensionPointTracker.open(ServicesExtensionPointTracker.java:32)
at org.eclipse.scout.service.internal.ServicesExtensionManager.start(ServicesExtensionManager.java:82)
at org.eclipse.scout.service.internal.Activator$1$1.run(Activator.java:63)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.ClassNotFoundException: org.eclipse.scout.rt.services.common.jdbc.AbstractJtdsSqlService
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
... 24 more
!ENTRY org.eclipse.scout.rt.shared 4 0 2012-10-21 16:23:39.453
!MESSAGE org.eclipse.scout.rt.shared.services.common.exceptionhandler.LogExceptionHandlerService.differentiatedLog(LogExceptionHandlerService.java:76) ProcessingStatus[ERROR code=0 invoking pt.diogoduarte.wforce.shared.services.outline.IStandardOutlineService:getContacts / service: class pt.diogoduarte.wforce.server.services.outline.StandardOutlineService, operation: getContacts, args: java.lang.NullPointerException]
!STACK 0
ProcessingException[ProcessingStatus[ERROR code=0 invoking pt.diogoduarte.wforce.shared.services.outline.IStandardOutlineService:getContacts / service: class pt.diogoduarte.wforce.server.services.outline.StandardOutlineService, operation: getContacts, args: java.lang.NullPointerException]]
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:189)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invokeImpl(DefaultTransactionDelegate.java:218)
at org.eclipse.scout.rt.server.DefaultTransactionDelegate.invoke(DefaultTransactionDelegate.java:92)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransactionWithDelegate(ServiceTunnelServlet.java:391)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.runServerJobTransaction(ServiceTunnelServlet.java:387)
at org.eclipse.scout.rt.server.ServiceTunnelServlet$RemoteServiceJob.runTransaction(ServiceTunnelServlet.java:415)
at org.eclipse.scout.rt.server.ServerJob.runTransactionWrapper(ServerJob.java:202)
at org.eclipse.scout.rt.server.ServerJob.access$0(ServerJob.java:190)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:161)
at org.eclipse.scout.rt.server.ServerJob$1.run(ServerJob.java:1)
at javax.security.auth.Subject.doAs(Unknown Source)
at org.eclipse.scout.rt.server.ServerJob.run(ServerJob.java:156)
at org.eclipse.scout.commons.job.JobEx.runNow(JobEx.java:50)
at org.eclipse.scout.rt.server.ServerJob.runNow(ServerJob.java:148)
at org.eclipse.scout.rt.server.ServiceTunnelServlet.doPost(ServiceTunnelServlet.java:296)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.scout.http.servletfilter.HttpServletEx.access$0(HttpServletEx.java:1)
at org.eclipse.scout.http.servletfilter.HttpServletEx$1.service(HttpServletEx.java:38)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:44)
at org.eclipse.scout.http.servletfilter.helper.HttpAuthJaasFilter.doFilter(HttpAuthJaasFilter.java:62)
at org.eclipse.scout.http.servletfilter.internal.FilterChainImpl.doFilter(FilterChainImpl.java:41)
at org.eclipse.scout.http.servletfilter.helper.DevelopmentAuthFilter.doFilter(DevelopmentAuthFilter.java:61)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilterInternal(AbstractChainableSecurityFilter.java:220)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.access$0(AbstractChainableSecurityFilter.java:219)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter$1.run(AbstractChainableSecurityFilter.java:157)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:149)
at org.eclipse.scout.http.servletfilter.security.AbstractChainableSecurityFilter.doFilter(AbstractChainableSecurityFilter.java:103)
at org.eclipse.scout.http.servletfilter.ServletFilterDelegate.delegateServiceMethod(ServletFilterDelegate.java:57)
at org.eclipse.scout.http.servletfilter.HttpServletEx.service(HttpServletEx.java:35)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:384)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:900)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:954)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:851)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
at org.eclipse.scout.rt.server.services.common.jdbc.SQL.select(SQL.java:101)
at pt.diogoduarte.wforce.server.services.outline.StandardOutlineService.getContacts(StandardOutlineService.java:13)
at org.eclipse.scout.service.ServiceUtility.invoke(ServiceUtility.java:172)
Please help me i'm getting crazy with this error.
Re: jdbc connection bundle SqlServer Jtds Drive [message #953308 is a reply to message #952567] Mon, 22 October 2012 02:14 Go to previous messageGo to next message
Jeremie Bresson is currently offline Jeremie Bresson
All you have done seems correct to me...
Do you start your application with the Scout SDK?
This use *.product files, to indicates which plugin will be included at runtime.
In the server plugin with "Require-Bundle:" you indicate the bundles that are required. In the product you indicate all plugins that should be loaded at runtime (it is possible to load more).
Try to open /{{your_project}}.server/products/development/{{your_project_name}}-server-dev.product
You can use validate to see if you are loading all required bundles.
I assume you will get an error because "org.eclipse.scout.rt.jdbc.jtds125" is missing.
You can add it with add.
index.php/fa/12003/0/
If you build and export your server (production), you need to do this in your production product:
/{your_project}}.server/products/production/{your_project_name}}-server.product
Re: jdbc connection bundle SqlServer Jtds Drive [message #953466 is a reply to message #953308] Mon, 22 October 2012 05:13 Go to previous messageGo to next message
Thanks for you reply J.
I allready have that dependency placed in the dev.product. I validated as you told me and it shows no problem at all:
index.php/fa/12006/0/
Is there any other way of debuging this error?
  • Attachment: im1.png
    (Size: 248.37KB, Downloaded 986 times)
Re: jdbc connection bundle SqlServer Jtds Drive [message #953603 is a reply to message #953466] Mon, 22 October 2012 07:37 Go to previous messageGo to next message
It was just a guess...
An other idea (for debugging) is to have a look at the console output when the server is started:
Here an example:
!SESSION 2012-10-22 13:32:56.962 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Framework arguments:  -product myproject.server.product
Command-line arguments:  -product myproject.server.product -data C:....../../runtime-MyProject-server-dev.product -dev file:C:....../.metadata/.plugins/org.eclipse.pde.core/MyProject-server-dev.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.equinox.http.jetty 4 0 2012-10-22 13:33:00.891
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [3]" could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.jetty.http; version="[8.0.0,9.0.0)"
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2012-10-22 13:33:00.915
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841.jar was not resolved.
Do you see OSGi BundleException??? (like the one I have reproduced here).
Re: jdbc connection bundle SqlServer Jtds Drive [message #953789 is a reply to message #953603] Mon, 22 October 2012 10:29 Go to previous messageGo to next message
I only get this:
!SESSION 2012-10-22 15:27:34.616 -----------------------------------------------
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=pt_PT
Framework arguments:  -product pt.diogoduarte.wforce.server.product
Command-line arguments:  -product pt.diogoduarte.wforce.server.product -data C:\eclipse\workspaces\scout/../runtime-wforce-server-dev.product -dev file:C:/eclipse/workspaces/scout/.metadata/.plugins/org.eclipse.pde.core/wforce-server-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.scout.service 4 0 2012-10-22 15:27:48.493
!STACK 0
	... 24 more
!ENTRY org.eclipse.scout.rt.shared 4 0 2012-10-22 15:27:49.038
!STACK 0
	... 62 more
Re: jdbc connection bundle SqlServer Jtds Drive [message #953794 is a reply to message #953789] Mon, 22 October 2012 10:36 Go to previous messageGo to next message
Is it possible that the bundle that i created:
isn't ACTIVE when i start the server?
Dont i have to install somehow the bundle in the (ECLIPSE)OSGI container?
Or does the server bundle automaticly requests the jdbc bundle to install in the osgi container?
Re: jdbc connection bundle SqlServer Jtds Drive [message #953834 is a reply to message #953794] Mon, 22 October 2012 11:15 Go to previous messageGo to next message
Sorry for wasting your time, but some how, i had the following build.propoerties:
output.. = bin/
bin.includes = META-INF/,\
               lib/jtds-1.2.5.jar,\
Missing the respective source line:
source.. = src/
output.. = bin/
This hapens when i add the lib\jtdsXXX.jar to the classpath and at the same time the editor adds a ".".
Then i deleted the point and this action removes the specified line.
Hope this situation can help someone in the future...
Thank you.
Re: jdbc connection bundle SqlServer Jtds Drive [message #954641 is a reply to message #953834] Tue, 23 October 2012 02:12 Go to previous message
I am glad your plug-in is now working...
It is no problem at all to discuss a problem in the forum. There are no wrong posts in this forum. Thanks for sharing.
Previous Topic:Multiple databases
Next Topic:Scout SDK and Eclipse preferences
Current Time: Sat May 25 07:52:51 EDT 2013
Powered by FUDForum. Page generated in 0.01912 seconds
