| Eclipse UML Plugins [message #950013] |
Fri, 19 October 2012 10:43  |
Al Was Messages: 2 Registered: October 2012 |
Junior Member |
Hello Eclipse Community,
I desperate on get any UML Plugin in Eclipse working well.
The installation is not the problem.
It becomes a problem when i try to start creating diagrams. it just freezes and i can't work well. I just can't create 1 Class. It just hangs and dont recognize my actions.
If i want to cancel the preparation of the view. Eclipse won't react.
I use ArchLinux(with awesome wm), Java 7, Eclipse(Juno, Indigo)
Only one tool works like the others should is called UML Designer http://marketplace.eclipse.org/content/uml-designer-indigo-version#.UIFmmoZYAaQ
I tried eUML its failed, UML-Tools failed. Installation works, but can't use because of the freezes.
I don't why its happening, do you have a solution for me?
with kind regards
Al Was
[Updated on: Fri, 19 October 2012 14:04] Report message to a moderator
FUDForum. Page generated in 0.02369 seconds
