Home » Modeling » EMF » CDO Explicit Lock works only for immediate children
CDO Explicit Lock works only for immediate children [message #951559] Sat, 20 October 2012 17:07 Go to next message
UmaShankar Subramani is currently offline UmaShankar Subramani
Member
When I lock an object explicitly(Right Click -> Locking -> Lock), only the immediate children of this object are actually locked too.
But I still, I could edit the other objects(grand children). So, If I want to lock all the children of the locked object(including all grandchildren), how can I do it.
I have the source installed.
Uma
[Updated on: Sat, 20 October 2012 17:08]
Report message to a moderator
Re: CDO Explicit Lock works only for immediate children [message #951909 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
Eike Stepper is currently offline Eike Stepper
Am 20.10.2012 23:07, schrieb UmaShankar Subramani:
That surprises me. Children should generally not be locked automatically. With 3 objects parent, child1 and child2 and a
write lock (by someone else) on parent you can't commit changes to parent's attributes or references. I.e. you can not
change the order of the children (because that's an aspect of the parent) but you can change attributes or references of
both children.
> But I still, I could edit the other objects(grand children). So, If how want to lock all the children of the locked
The last parameter of this method is "recursive":
CDOView.lockObjects(Collection<? extends CDOObject>, LockType, long, boolean)
Cheers
/Eike
http://www.esc-net.de
Re: CDO Explicit Lock works only for immediate children [message #951916 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951923 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951930 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951937 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951944 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951951 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951958 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951965 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951972 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951979 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951986 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #951993 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952000 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952007 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952014 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952021 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952028 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952036 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952044 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Re: CDO Explicit Lock works only for immediate children [message #952051 is a reply to message #951559] Sun, 21 October 2012 00:05 Go to previous message
both children.
Cheers
/Eike
Previous Topic:Decoration layer over EMF
Next Topic:Codegenerated UI Examples for model with a large number of EClasses
Current Time: Tue May 21 06:00:45 EDT 2013
Powered by FUDForum. Page generated in 0.02946 seconds
