Home » Eclipse Projects » BIRT » font in dynamic content of text
font in dynamic content of text [message #949682] Fri, 19 October 2012 03:30 Go to next message
hage Mising name is currently offline hage Mising name
Member
if i create a textfield and generate the content in its onRender()-Method, my assigned font (style and size) are ignored when rendering to pdf. Output is always a serif font, but my setting is arial. this only seems to appear in pdfemitter, html/doc/odt works as expected. i guess it's something wrong with my pdf viewer, isnt it?
hage
Re: font in dynamic content of text [message #950610 is a reply to message #949682] Fri, 19 October 2012 22:02 Go to previous message
Michael Williams is currently offline Michael Williams
You could check your fontsConfig_pdf file, to see if there is a mapping set up that would map Arial to serif, in PDF. You also might make sure you have a ttf file for Arial in one of the directories pointed to by your fontsConfig.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Dynamic dial chart scale
Next Topic:Cant't show Dynamic Image from Sqlite Database
Current Time: Sat May 18 13:39:11 EDT 2013
Powered by FUDForum. Page generated in 0.02710 seconds
