Home » Newcomers » Newcomers » Content Assist Background is BLACK(Can't change the Content Assist Background from BLACK)
Content Assist Background is BLACK [message #950247] Fri, 19 October 2012 14:59 Go to next message
Robert Lockwood is currently offline Robert Lockwood
Member
I just made a clean install of Ubuntu 11.10, downloaded and installed Oracle Java JDK and JRE, version 7, and downloaded Eclipse Juno from eclipse.org and unpacked it to a folder. I started Eclipse, imported a preferece file, and then opened an exsiting workspace.
When Content Assist appears the background is black which is a bit strange but the white text is readable, what is unreadable is the dark blue text which details any sugggested options.
I've made preference changes to make the background yellow but nothing changes.
Anyone know how make the Content Assist Popup readable?
Re: Content Assist Background is BLACK [message #950301 is a reply to message #950247] Fri, 19 October 2012 16:01 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
You need to set the color in the Ubuntu Appearance preferences.
Re: Content Assist Background is BLACK [message #954105 is a reply to message #950247] Mon, 22 October 2012 15:51 Go to previous messageGo to next message
Member
Apparently Ubuntu Appearance preferences doesn't exist in Ubuntu 11.10.
http://ubuntuforums.org/showthread.php?t=1871156
Crying or Very Sad
Re: Content Assist Background is BLACK [message #954127 is a reply to message #954105] Mon, 22 October 2012 16:11 Go to previous messageGo to next message
Russell Bateman is currently offline Russell Bateman
> :cry:
There are a couple of things you can do. The one I use is System ->
Preferences -> Appearances -> Theme -> Clearlooks. Obviously, this has a
radical effect on the rest of your desktop theme experience, but it's
perfect for what you're trying to solve.
Re: Content Assist Background is BLACK [message #955400 is a reply to message #954127] Tue, 23 October 2012 15:22 Go to previous message
Member
@Russell
I don't have ClearLooks but I did solve the problem.
UBUNTU:
System->Appearance->Theme->Adwaita
ECLIPSE:
Window->Preferences->General->Appearance->Theme->GTK
and
Window->Preferences->General->Appearance->Color & Fonts->Content Assist
The title to my JFrom is now centered, too, as an added benefit.
Thanks!
I have another machine that was upgraded twice, finally to 11.10. I had fixed this on it with no problem a long time ago. Probably some debris from the earlier OS was left behind.
Previous Topic:CVS repository
Next Topic:Troubles getting a build to work.
Current Time: Fri May 24 12:31:57 EDT 2013
Powered by FUDForum. Page generated in 0.01723 seconds
