| Wizard generated WSDL based client does not include namespace in the Method definitions [message #719748] |
Sun, 28 August 2011 14:45  |
Patrick Sofin Messages: 2 Registered: August 2011 |
Junior Member |
Greetings all:
["//" was removed in all instances from "http" in this message so that links would be disabled.]
I am attempting to build sample code for JAXWS using Apache CXF 2.4.2 Web Tools version 3.0 on Windows 7 Ultimate with Java SDK v1.7 and Apache Tomcat v7.0 in the Eclipse Indigo IDE V3.7.
I am loosely following the JAXWS Video sample "Deploy a service to Tomcat" which is somewhat out of date.
I am able to successfully create a Java Beans bottom up server instance using these instructions, and I can deploy this service to Tomcat 7.0 and see the service in my browser window, and attached to the Tomcat server in my "servers" window.
Available SOAP services:
Converter_WSDL2
celsiusToFarenheit
farenheitToCelsius
Endpoint address: http:localhost:8080/Converter_WSDL2/services/Converter_WSDL2Port
WSDL : {http:example.iona.com/}Converter_WSDL2Service
Target namespace: http:example.iona.com/
Available RESTful services:
The XML schema follows (seems fine to me):
<?xml version="1.0" encoding="utf-8"?><xs:schema xmlns:xs="http:www.w3.org/2001/XMLSchema" xmlns:tns="http:example.iona.com/" elementFormDefault="unqualified" targetNamespace="http:example.iona.com/" version="1.0">
<xs:element name="celsiusToFarenheit" type="tns:celsiusToFarenheit"/>
<xs:element name="celsiusToFarenheitResponse" type="tns:celsiusToFarenheitResponse"/>
<xs:element name="farenheitToCelsius" type="tns:farenheitToCelsius"/>
<xs:element name="farenheitToCelsiusResponse" type="tns:farenheitToCelsiusResponse"/>
<xs:complexType name="celsiusToFarenheit">
<xs:sequence>
<xs:element name="arg0" type="xs:float"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="celsiusToFarenheitResponse">
<xs:sequence>
<xs:element name="return" type="xs:float"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="farenheitToCelsius">
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:complexType name="farenheitToCelsiusResponse">
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:schema>
The WSDL is here (seems fine to me):
<wsdl:definitions name="Converter_WSDL2Service" targetNamespace="http:example.iona.com/" xmlns:wsdl="http:schemas.xmlsoap.org/wsdl/" xmlns:tns="http:example.iona.com/" xmlns:xsd="http:www.w3.org/2001/XMLSchema" xmlns:soap="http:schemas.xmlsoap.org/wsdl/soap/">
<wsdl:types>
<schema xmlns="http:www.w3.org/2001/XMLSchema">
<import namespace="http:example.iona.com/" schemaLocation="converter_wsdl2_schema1.xsd"/>
</schema>
</wsdl:types>
<wsdl:message name="celsiusToFarenheitResponse">
<wsdl:part name="parameters" element="tns:celsiusToFarenheitResponse">
</wsdl:part>
</wsdl:message>
<wsdl:message name="farenheitToCelsiusResponse">
<wsdl:part name="parameters" element="tns:farenheitToCelsiusResponse">
</wsdl:part>
</wsdl:message>
<wsdl:message name="farenheitToCelsius">
<wsdl:part name="parameters" element="tns:farenheitToCelsius">
</wsdl:part>
</wsdl:message>
<wsdl:message name="celsiusToFarenheit">
<wsdl:part name="parameters" element="tns:celsiusToFarenheit">
</wsdl:part>
</wsdl:message>
<wsdl:portType name="Converter_WSDL2">
<wsdl:operation name="celsiusToFarenheit">
<wsdl:input name="celsiusToFarenheit" message="tns:celsiusToFarenheit">
</wsdl:input>
<wsdl:output name="celsiusToFarenheitResponse" message="tns:celsiusToFarenheitResponse">
</wsdl:output>
</wsdl:operation>
<wsdl:operation name="farenheitToCelsius">
<wsdl:input name="farenheitToCelsius" message="tns:farenheitToCelsius">
</wsdl:input>
<wsdl:output name="farenheitToCelsiusResponse" message="tns:farenheitToCelsiusResponse">
</wsdl:output>
</wsdl:operation>
</wsdl:portType>
<wsdl:binding name="Converter_WSDL2ServiceSoapBinding" type="tns:Converter_WSDL2">
<soap:binding style="document" transport="http:schemas.xmlsoap.org/soap/http"/>
<soap:operation soapAction="urn:CelsiusToFarenheit" style="document"/>
<wsdl:input name="celsiusToFarenheit">
<soap:body use="literal"/>
</wsdl:input>
<wsdl:output name="celsiusToFarenheitResponse">
</wsdl:output>
</wsdl:operation>
<soap:operation soapAction="urn:FarenheitToCelsius" style="document"/>
<wsdl:input name="farenheitToCelsius">
</wsdl:input>
<wsdl:output name="farenheitToCelsiusResponse">
</wsdl:output>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="Converter_WSDL2Service">
<wsdl:port name="Converter_WSDL2Port" binding="tns:Converter_WSDL2ServiceSoapBinding">
<soap:address location="http:localhost:8080/Converter_WSDL2/services/Converter_WSDL2Port"/>
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
I have made several attempts to create a successful client using the "Web Service Client" wizard within the Eclipse IDE.
When I attempt to run the client as a Java application I get variations on this error:
Aug 28, 2011 8:16:43 AM org.apache.cxf.service.factory.ReflectionServiceFactoryBean buildServiceFromWSDL
INFO: Creating Service {http:example.iona.com/}Converter_WSDL2Service from WSDL: http:localhost:8080/Converter_WSDL2/services/Converter_WSDL2Port?wsdl
Invoking celsiusToFarenheit...
Exception in thread "main" javax.xml.ws.soap.SOAPFaultException: Unmarshalling Error: unexpected element (uri:"http:example.iona.com/", local:"arg0"). Expected elements are <{}arg0>
at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:156)
at $Proxy25.celsiusToFarenheit(Unknown Source)
at com.iona.example.client.ConverterWSDL2_ConverterWSDL2Port_Client.main(ConverterWSDL2_ConverterWSDL2Port_Client.java:55)
Caused by: org.apache.cxf.binding.soap.SoapFault: Unmarshalling Error: unexpected element (uri:"http:example.iona.com/", local:"arg0"). Expected elements are <{}arg0>
at org.apache.cxf.binding.soap.interceptor.Soap11FaultInInterceptor.unmarshalFault(Soap11FaultInInterceptor.java:75)
at org.apache.cxf.binding.soap.interceptor.Soap11FaultInInterceptor.handleMessage(Soap11FaultInInterceptor.java:46)
at org.apache.cxf.binding.soap.interceptor.Soap11FaultInInterceptor.handleMessage(Soap11FaultInInterceptor.java:35)
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:263)
at org.apache.cxf.interceptor.AbstractFaultChainInitiatorObserver.onMessage(AbstractFaultChainInitiatorObserver.java:105)
at org.apache.cxf.binding.soap.interceptor.CheckFaultInterceptor.handleMessage(CheckFaultInterceptor.java:69)
at org.apache.cxf.binding.soap.interceptor.CheckFaultInterceptor.handleMessage(CheckFaultInterceptor.java:34)
at org.apache.cxf.endpoint.ClientImpl.onMessage(ClientImpl.java:771)
at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleResponseInternal(HTTPConduit.java:1600)
at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.handleResponse(HTTPConduit.java:1485)
at org.apache.cxf.transport.http.HTTPConduit$WrappedOutputStream.close(HTTPConduit.java:1393)
at org.apache.cxf.transport.AbstractConduit.close(AbstractConduit.java:56)
at org.apache.cxf.transport.http.HTTPConduit.close(HTTPConduit.java:640)
at org.apache.cxf.interceptor.MessageSenderInterceptor$MessageSenderEndingInterceptor.handleMessage(MessageSenderInterceptor.java:62)
at org.apache.cxf.endpoint.ClientImpl.doInvoke(ClientImpl.java:519)
at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:449)
at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:352)
at org.apache.cxf.endpoint.ClientImpl.invoke(ClientImpl.java:304)
at org.apache.cxf.frontend.ClientProxy.invokeSync(ClientProxy.java:88)
at org.apache.cxf.jaxws.JaxWsClientProxy.invoke(JaxWsClientProxy.java:134)
... 2 more
Research on this issue suggests that the problem may be caused by the fact that the server method and the client method, as created by the WTP Wizards, do not match. The namespace is defined for these arguments in the server method, but not in the client method.
Here is the offending method on the server instance (note the presence of "namespace" on the "@XmlType" label):
package com.iona.example.jaxws;
import javax.xml.bind.annotation.XmlAccessType;
import javax.xml.bind.annotation.XmlAccessorType;
import javax.xml.bind.annotation.XmlElement;
import javax.xml.bind.annotation.XmlRootElement;
import javax.xml.bind.annotation.XmlType;
* This class was generated by Apache CXF 2.4.2
* Sun Aug 28 07:35:44 MDT 2011
* Generated source version: 2.4.2
@XmlRootElement(name = "celsiusToFarenheit", namespace = "http:example.iona.com/")
@XmlAccessorType(XmlAccessType.FIELD)
@XmlType(name = "celsiusToFarenheit", namespace = "http:example.iona.com/")
public class CelsiusToFarenheit {
@XmlElement(name = "arg0")
private float arg0;
public float getArg0() {
return this.arg0;
public void setArg0(float newArg0) {
this.arg0 = newArg0;
Here is the companion method on the client instance (note the absence of "namespace" on the "@XmlType" label):
package com.iona.example.client;
* <p>Java class for celsiusToFarenheit complex type.
* <p>The following schema fragment specifies the expected content contained within this class.
* <pre>
* <complexType name="celsiusToFarenheit">
* <complexContent>
* <restriction base="{http:www.w3.org/2001/XMLSchema}anyType">
* <sequence>
* <element name="arg0" type="{http:www.w3.org/2001/XMLSchema}float"/>
* </sequence>
* </restriction>
* </complexContent>
* </complexType>
* </pre>
@XmlType(name = "celsiusToFarenheit", propOrder = {
"arg0"
protected float arg0;
* Gets the value of the arg0 property.
return arg0;
* Sets the value of the arg0 property.
public void setArg0(float value) {
this.arg0 = value;
I tried making these changes with no luck:
//@XmlRootElement(name = "celsiusToFarenheit", namespace = "http:example.iona.com/")
@XmlRootElement(name = "celsiusToFarenheit")
//@XmlType(name = "celsiusToFarenheit", namespace = "http:example.iona.com/")
@XmlType(name = "celsiusToFarenheit")
private float arg0;
return this.arg0;
If I could get the WTP wizard to add the namespace to the client generated code, this problem would probably go away.
I tried changing the Schema value of elementFormDefault from "unqualified" to "qualified", then rebuilding the client using the wizard. No luck here.
Can any one help me with this issue?
| Re: Wizard generated WSDL based client does not include namespace in the Method definitions [message #719753 is a reply to message #719748] |
Sun, 28 August 2011 15:22   |
Junior Member |
Greetings again:
["//" is removed from all "http" to disable links in this message.]
I rebuilt the project from scratch (again) and I got a new but similar error:
Aug 28, 2011 12:58:58 PM org.apache.cxf.service.factory.ReflectionServiceFactoryBean buildServiceFromWSDL
INFO: Creating Service {http:example.iona.com/}Converter_WSDLService from WSDL: http:localhost:8080/Converter_WSDL/services/Converter_WSDLPort?wsdl
Aug 28, 2011 12:58:59 PM org.apache.cxf.phase.PhaseInterceptorChain doDefaultLogging
WARNING: Interceptor for {http:example.iona.com/}Converter_WSDLService#{http:example.iona.com/}celsiusToFarenheit has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Unmarshalling Error: unexpected element (uri:"http:example.iona.com/", local:"return"). Expected elements are <{}return>
at org.apache.cxf.jaxb.JAXBEncoderDecoder.unmarshall(JAXBEncoderDecoder.java:791)
at org.apache.cxf.jaxb.JAXBEncoderDecoder.unmarshall(JAXBEncoderDecoder.java:632)
at org.apache.cxf.jaxb.io.DataReaderImpl.read(DataReaderImpl.java:156)
at org.apache.cxf.interceptor.DocLiteralInInterceptor.handleMessage(DocLiteralInInterceptor.java:109)
at com.iona.example.client.ConverterWSDL_ConverterWSDLPort_Client.main(ConverterWSDL_ConverterWSDLPort_Client.java:55)
Caused by: javax.xml.bind.UnmarshalException
- with linked exception:
[com.sun.istack.SAXParseException2; lineNumber: 1; columnNumber: 151; unexpected element (uri:"http:example.iona.com/", local:"return"). Expected elements are <{}return>]
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.handleStreamException(UnmarshallerImpl.java:425)
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:362)
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:339)
at org.apache.cxf.jaxb.JAXBEncoderDecoder.unmarshall(JAXBEncoderDecoder.java:768)
... 20 more
Caused by: com.sun.istack.SAXParseException2; lineNumber: 1; columnNumber: 151; unexpected element (uri:"http:example.iona.com/", local:"return"). Expected elements are <{}return>
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallingContext.handleEvent(UnmarshallingContext.java:642)
at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.reportError(Loader.java:254)
at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.reportError(Loader.java:249)
at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.reportUnexpectedChildElement(Loader.java:116)
at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.childElement(Loader.java:101)
at com.sun.xml.bind.v2.runtime.unmarshaller.StructureLoader.childElement(StructureLoader.java:243)
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallingContext._startElement(UnmarshallingContext.java:478)
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallingContext.startElement(UnmarshallingContext.java:459)
at com.sun.xml.bind.v2.runtime.unmarshaller.StAXStreamConnector.handleStartElement(StAXStreamConnector.java:242)
at com.sun.xml.bind.v2.runtime.unmarshaller.StAXStreamConnector.bridge(StAXStreamConnector.java:176)
at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:360)
... 22 more
Caused by: javax.xml.bind.UnmarshalException: unexpected element (uri:"http:example.iona.com/", local:"return"). Expected elements are <{}return>
... 33 more
Exception in thread "main" javax.xml.ws.soap.SOAPFaultException: Unmarshalling Error: unexpected element (uri:"http:example.iona.com/", local:"return"). Expected elements are <{}return>
... 2 more
... 22 more
... 33 more
I changed the CelsiusToFarenheitResponse class on the server:
* Sat Aug 27 22:31:42 MDT 2011
@XmlRootElement(name = "celsiusToFarenheitResponse", namespace = "http:example.iona.com/")
@XmlType(name = "celsiusToFarenheitResponse", namespace = "http:example.iona.com/")
public class CelsiusToFarenheitResponse {
//@XmlElement(name = "return", namespace = "http:example.iona.com/")
@XmlElement(name = "return")
private float _return;
public float getReturn() {
return this._return;
public void setReturn(float new_return) {
this._return = new_return;
and the FarenheitToCelsiusResponse class on the server:
@XmlRootElement(name = "farenheitToCelsiusResponse", namespace = "http:example.iona.com/")
@XmlType(name = "farenheitToCelsiusResponse", namespace = "http:example.iona.com/")
public class FarenheitToCelsiusResponse {
I suspect that the original namespace error may have been due to creating a client instance using the elementFormDefault="qualified" change (from "unqualified") in the original XMl Schema.
I restarted the server and I got this output from the client:
Aug 28, 2011 1:08:47 PM org.apache.cxf.service.factory.ReflectionServiceFactoryBean buildServiceFromWSDL
celsiusToFarenheit.result=289.4
Invoking farenheitToCelsius...
farenheitToCelsius.result=22.777779
Clearly, this example is working now.
But why do I have to edit the Wizard generated server code and remove the namespace qualifiers?
How can I use the wizard to generate server and client code that does not need to be modified further to run?
Do I need to stop generating client code using the server WSDL?
namespaces can be very important. What would I do to make this code work and still keep the namespace designations?
Can anyone help me with this problem?
FUDForum. Page generated in 0.01694 seconds
