Home » Modeling » OCL » Ecore derived attribute's derivation specialization
Ecore derived attribute's derivation specialization [message #949959] Fri, 19 October 2012 09:42 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising name
I would like to know the possibility of overriding the ocl derivation statements of derived attribute in specialization class?
Is it supported in Ecore?
Re: Ecore derived attribute's derivation specialization [message #949983 is a reply to message #949959] Fri, 19 October 2012 10:10 Go to previous messageGo to next message
I'm not entirely clear what you mean.
Generally (UML, Java, Ecore), Properties are not overrideable, although
in UML they are redefinable.
If you want overriding you should use Operations, and if you want it to
look like a Property, introduce a Property at the root that delegates to
an Operation.
Ed Willink
On 19/10/2012 14:42, ModelGeek Mising name wrote:
> Cheers,
Re: Ecore derived attribute's derivation specialization [message #950002 is a reply to message #949983] Fri, 19 October 2012 10:32 Go to previous message
thanks!
Previous Topic:Validate OCL constraints on XMI model
Next Topic:OCL in XText Editor
Current Time: Fri May 24 01:28:44 EDT 2013
Powered by FUDForum. Page generated in 0.01781 seconds
