Home » Eclipse Projects » Buckminster » How do I alterProperties for site.p2?
How do I alterProperties for site.p2? [message #949988] Fri, 19 October 2012 10:19 Go to next message
Matthew Webber is currently offline Matthew Webber
I have a standard site feature with a standard create.product in a .cspex with associated ant build file. It all works ok, but now I want to force the site.p2 action to use target.os=target.ws=target.arch=*, instead of having to specify them in a buckminster.properties file.
I added the following to my .cspex, but it does not work - in fact, Buckminster cannot parse the file, and reports:
Project refresh on xxx.site failed: No component named xxx.site is known to Buckminster
<alterActions>
	<!-- Place your Action alterations here -->
	<public name="site.p2" actor="p2SiteGenerator">
		<alterProperties>
			<property key="target.os" value="*"/>
			<property key="target.ws" value="*"/>
			<property key="target.arch" value="*"/>
		</alterProperties>
	</public>
</alterActions>
So, what am I doing wrong? The syntax looks ok according to the BuckyBook and schemas.
Matthew
[Updated on: Fri, 19 October 2012 10:26]
Report message to a moderator
Re: How do I alterProperties for site.p2? [message #949992 is a reply to message #949988] Fri, 19 October 2012 10:21 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis Huebner
<alterActions>
</alterAction>
+Dennis Hübner
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: How do I alterProperties for site.p2? [message #949998 is a reply to message #949992] Fri, 19 October 2012 10:27 Go to previous message
Sorry, that was a copy/paste error (now corrected). The actual XML I was using was correct.
Thanks for the quick response anyhow.
To clarify: the XML tags are correct, but I get the problem as originally described.
[Updated on: Fri, 19 October 2012 10:28]
Previous Topic:Selectively hide some source features in the update site
Next Topic:Building product for Eclipse 3.7+
Current Time: Tue May 21 14:49:13 EDT 2013
Powered by FUDForum. Page generated in 0.09177 seconds
