Home » Eclipse Projects » Eclipse Platform » A question about IDocumentProvider
A question about IDocumentProvider [message #946997] Tue, 16 October 2012 14:13 Go to next message
Raymond Missing name is currently offline Raymond Missing name
Member
Hey guys,
I need to use org.eclipse.ui.texteditor.IDocumentProvider in my plug-in. I looked into the interface and its implementations and I found the connect(object) method is not synchronized. Is it thread safe?
Thanks.
Raymond
Re: A question about IDocumentProvider [message #947574 is a reply to message #946997] Wed, 17 October 2012 03:48 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 16.10.2012 20:13, Raymond Mising name wrote:
> Hey guys,
Almost all types in *.ui.* packages are supposed to run in the UI thread
and hence not explicitly made thread-safe.
Dani
> Thanks.
> Raymond
Re: A question about IDocumentProvider [message #949223 is a reply to message #946997] Thu, 18 October 2012 16:26 Go to previous messageGo to next message
Member
Thanks Dani. In the org.eclipse.ui.editors.text.TextFileDocumentProvider#connect() method. I saw it accounted the number of how many clients were connected by doing ++ info.fCount. But I could not think of any case that can make the connected clients to be more than one. Can you give me an example? Thanks.
Re: A question about IDocumentProvider [message #949805 is a reply to message #949223] Fri, 19 October 2012 06:07 Go to previous messageGo to next message
On 18.10.2012 22:26, Raymond Mising name wrote:
> Thanks Dani. In the
e.g. open more than one editor on the same file.
Dani
> Thanks.
Re: A question about IDocumentProvider [message #949966 is a reply to message #949805] Fri, 19 October 2012 09:52 Go to previous messageGo to next message
Member
I tried that but it always jumped to the opened editor. How can open multiple editors on one file?
Re: A question about IDocumentProvider [message #949979 is a reply to message #949966] Fri, 19 October 2012 10:04 Go to previous message
Window > New Editor
Dani
Previous Topic:Open file at line from command line
Next Topic:Eclipse 4.2 appearance
Current Time: Wed May 22 13:34:15 EDT 2013
Powered by FUDForum. Page generated in 0.02331 seconds
