Home » Modeling » Ecore Tools » Resolve Ecore Cross Reference
Resolve Ecore Cross Reference [message #949027] Thu, 18 October 2012 12:04
Florian B. is currently offline Florian B.
Hi folks,
I have a problem concerning the resolving of ecore cross references.
In my model I have cross references from entities to the same entity in a different file.
In my ecore model the reference's upper bound is set to unbounded and the lower bound is set to 1.
The problem is, when the XML are parsed and I want to access the referenced objects in foo as single entities, these objects (in my case "ports") are null. It seems the factory returns just new objects of the types.
<foo>
 <refPort>bar_test.bar_specification#//@devices/@device[name='testDevice1']/@port[name='TestDevice1Port']</refPort>
 <refPort>bar_test.bar_specification#//@devices/@device[name='testDevice2']/@port[name='TestDevice2Port']</refPort>
</foo>
The weird thing is, the references seems to be resolved, if only one referenced object is defined in the XML document as attribute of foo, like the following example.
<foo
refport="bar_test.bar_specification#//@devices/@device[name='testDevice1']/@port[name='TestDevice1Port']" />
Maybe some properties are wrong in the .ecore ?
Thx again,
Florian
EDIT1:
I also tried to resolve the references with the static method EcoreUtil.resolveAll()
[Updated on: Thu, 18 October 2012 12:09]
Report message to a moderator
Previous Topic:Trouble installing/using Ecore Tools SDK
Next Topic:Creating Diagrams for a subset of objects in the Ecore Model
Current Time: Tue May 28 11:03:25 EDT 2013
Powered by FUDForum. Page generated in 0.01471 seconds
