| Re: [MDT-OclInEcore] Code executed for dynamic instances but not for generated editor [message #947838 is a reply to message #947804] |
Wed, 17 October 2012 09:43  |
Ed Willink Messages: 3191 Registered: July 2009 |
Please use the OCL newsgroup for OCL discussions.
I'm afraid that "it does not work" is not often likely to get a useful
answer.
There are often tens of reasons why things might not work. I do not have
time to list them all and none of them may be appropriate.
Of particular importance is the Eclipse OCL version you are using. Juno
adds the ability to generate Java code directly.
Ed Willink
On 17/10/2012 14:03, Ralph Gerbig wrote:
> Hi all,
> I used the OCLInEcore editor to specify OCL constraints. These get
> executed fine for dynamic instances. If I generate code and try to get
> the OCL executed in a target workbench it does not work. Any hints? I
> set OperationRefelection to true and Java to Version 6.0.
> Thanks Ralph
FUDForum. Page generated in 0.01499 seconds
