Home » Eclipse Projects » WindowBuilder » Setting background image
Setting background image [message #723479] Thu, 08 September 2011 12:20 Go to next message
RD  is currently offline RD
I want to add a background image to a composite. Is there an easy way of doing this using the WindowBuilder GUI? I'm looking at the composite's properties, and I see that I can change the background color, but I don't see a field where I can set a background image.
Thanks.
Re: Setting background image [message #723491 is a reply to message #723479] Thu, 08 September 2011 12:45 Go to previous messageGo to next message
Konstantin Scheglov is currently offline Konstantin Scheglov
SWT does not provide such method, so there are no such property in WB.
Konstantin Scheglov,
Google, Inc.
Re: Setting background image [message #947540 is a reply to message #723491] Wed, 17 October 2012 03:10 Go to previous message
ZERO ZERO is currently offline ZERO ZERO
You can set a background image by using the JLabel, resize it to the size you wish, then choose the background image you want in the icon from Jlabel properties windows Smile
source: youtube video name [JFrame Add Background Image]
Previous Topic:Window Builder , Form Designer
Next Topic:Change form format of WindowBuilder
Current Time: Wed May 22 10:26:14 EDT 2013
Powered by FUDForum. Page generated in 0.07321 seconds
