Home » Eclipse Projects » Hudson » Can hudson deploy to a resin server(Hudson Resin)
Can hudson deploy to a resin server [message #947149] Tue, 16 October 2012 17:29 Go to next message
joveen chacko is currently offline joveen chacko
Can someone tell me if deployment of jar to a resin server after a hudson build is possible?
Re: Can hudson deploy to a resin server [message #947197 is a reply to message #947149] Tue, 16 October 2012 18:45 Go to previous messageGo to next message
Steve Christou is currently offline Steve Christou
It should be possible to deploy a .jar to a resin server. I believe there are plugins to copy artifacts. http://wiki.hudson-ci.org/display/HUDSON/Copy+Artifact+Plugin
 * @author Steven Christou
 * @dev    Hudson-ci
Re: Can hudson deploy to a resin server [message #947228 is a reply to message #947197] Tue, 16 October 2012 19:35 Go to previous message
Winston Prakash is currently offline Winston Prakash
Another options is to add Resin support to Deploy Plugin. Deploy Plugin is based on Cargo (cargo.codehaus.org/). Cargo supports Resin. So should be easy to add Deployment to Resin server in the Deploy plugin
Winston Prakash
Eclipse Hudson team
Previous Topic:workspaceFormat not working in SVN plugin 2.3.4-h-1
Next Topic:Attempting to set up a Build Once Deploy Many job chain using several Hudson plugins, but ...
Current Time: Sun May 19 02:51:02 EDT 2013
Powered by FUDForum. Page generated in 0.01714 seconds
