| Re: Does Egit support shallow clone yet? [message #968233 is a reply to message #946737] |
Fri, 02 November 2012 05:55  |
Maxmelbin Neson Messages: 3 Registered: October 2012 |
Junior Member |
If we try to load an existing shallow clone, JGit crashes with error as shown below.
"Could not create the view: Walk failure.".
It is missing the parent commit of the deepest commit in the shallow clone:
Error log below:
org.eclipse.jgit.errors.MissingObjectException: Missing commit a71254bb3286faaccd62084c96d3d2f07f9fb0b5
at org.eclipse.jgit.storage.file.WindowCursor.open(WindowCursor.java:126)
at org.eclipse.jgit.revwalk.RevWalk.getCachedBytes(RevWalk.java:859)
at org.eclipse.jgit.revwalk.RevCommit.parseHeaders(RevCommit.java:136)
at org.eclipse.jgit.revwalk.PendingGenerator.next(PendingGenerator.java:148)
at org.eclipse.jgit.revwalk.DelayRevQueue.next(DelayRevQueue.java:86)
at org.eclipse.jgit.revwalk.FixUninterestingGenerator.next(FixUninterestingGenerator.java:77)
at org.eclipse.jgit.revwalk.StartGenerator.next(StartGenerator.java:181)
at org.eclipse.jgit.revwalk.RevWalk.next(RevWalk.java:420)
at org.eclipse.jgit.revwalk.RevWalk.iterator(RevWalk.java:1232)
at org.eclipse.jgit.revwalk.RevWalkUtils.find(RevWalkUtils.java:129)
at org.eclipse.jgit.revwalk.RevWalkUtils.count(RevWalkUtils.java:94)
at org.eclipse.jgit.lib.BranchTrackingStatus.of(BranchTrackingStatus.java:100)
at org.eclipse.egit.ui.internal.GitLabelProvider.getStyledTextFor(GitLabelProvider.java:178)
at org.eclipse.egit.ui.internal.repository.RepositoriesViewLabelProvider.getStyledText(RepositoriesViewLabelProvider.java:370)
at org.eclipse.ui.internal.navigator.extensions.SafeDelegateCommonLabelProvider.getStyledText(SafeDelegateCommonLabelProvider.java:118)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceLabelProvider.findStyledText(NavigatorContentServiceLabelProvider.java:165)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceLabelProvider.getStyledText(NavigatorContentServiceLabelProvider.java:151)
at org.eclipse.ui.internal.navigator.NavigatorDecoratingLabelProvider$StyledLabelProviderAdapter.getStyledText(NavigatorDecoratingLabelProvider.java:68)
at org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider.getStyledText(DelegatingStyledCellLabelProvider.java:195)
at org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider.getStyledText(DecoratingStyledCellLabelProvider.java:192)
at org.eclipse.ui.internal.navigator.NavigatorDecoratingLabelProvider.getText(NavigatorDecoratingLabelProvider.java:222)
at org.eclipse.jface.viewers.ViewerComparator.compare(ViewerComparator.java:136)
at org.eclipse.ui.navigator.CommonViewerSorter.compare(CommonViewerSorter.java:140)
at org.eclipse.jface.viewers.TreePathViewerSorter$1.compare(TreePathViewerSorter.java:105)
at java.util.Arrays.mergeSort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at org.eclipse.jface.viewers.TreePathViewerSorter.sort(TreePathViewerSorter.java:103)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:624)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:805)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:782)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:753)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1533)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:833)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1517)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1443)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:403)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1404)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1510)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1690)
at org.eclipse.ui.navigator.CommonNavigator.createPartControl(CommonNavigator.java:212)
at org.eclipse.egit.ui.internal.repository.RepositoriesView.createPartControl(RepositoriesView.java:331)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActive(WorkbenchPage.java:4317)
at org.eclipse.ui.internal.WorkbenchPage$18.runWithException(WorkbenchPage.java:3359)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
FUDForum. Page generated in 0.06671 seconds
