Home » Eclipse Projects » Jubula » Need Mouse Down and Up Action(I want to use the Mouse Down from one position and Mouse Up at another position to achive select a calendar area)
Need Mouse Down and Up Action [message #946529] Tue, 16 October 2012 05:11 Go to next message
Lizzy Liu is currently offline Lizzy Liu
I encounter a component which Jubula can't recognise, the component is to set the Calendar time by draging the mouse from one point to another point. But I see there only drag action in the Jubula library, which seems to drag a component from one place to another. So I want to use the Mouse Down then Up action to achive this, but I don't know how to do this? Is there any instructions to write the Mouse Down and Mouse Up action? Thanks a lot.
  • Attachment: Calendar.png
    (Size: 1.94KB, Downloaded 21 times)
Re: Need Mouse Down and Up Action [message #946652 is a reply to message #946529] Tue, 16 October 2012 07:23 Go to previous message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
There are also drop actions in the library: every drag action also has a corresponding drop action.
HTH,
Alex
Previous Topic:How can I add an own function to jubula
Next Topic:check fails - Actual value returned is wrong
Current Time: Sun May 26 05:35:38 EDT 2013
Powered by FUDForum. Page generated in 0.01455 seconds
