Home » Eclipse Projects » Eclipse 4 » Re: e4 Eclipse 4 - about dialog
Re: e4 Eclipse 4 - about dialog [message #945315] Mon, 15 October 2012 06:40 Go to next message
Thomas Schindl is currently offline Thomas Schindl
Are you running with the compat layer? All you show is part of the
compat layer and you can't simply use it in a plain e4 app.
Like in the other reply please ask such questions on the e4 newsgroup.
Tom
Am 11.10.12 19:21, schrieb Alex Kipling:
> Hello, I am building an Eclipse 4 Application and I would like to make
> an about dialog as known from Eclipse 3.
> I used the Menu Spy and learned the following:
> Theactive contribution location URI:
> menu:help?after=about
> The active action definition identifier:
> org.eclipse.ui.help.aboutAction
> The active contribution item class:
> ActionFactory$WorkbenchCommandAction
> The contributing plug-in:
> org.eclipse.ui.workbench
> Can I somehow use this action to open or extend the about dialog in my
> application?
Re: e4 Eclipse 4 - about dialog [message #962165 is a reply to message #945315] Sun, 28 October 2012 18:53 Go to previous message
Lars Vogel is currently offline Lars Vogel
The default Eclipse 3 "About Dialog" is not supported but you can easily build your own dialog. See Eclipse Dialog tutorial for several examples.
Previous Topic:Eclipse custom DI
Next Topic:Adding a status bar to an E4 RCP application
Current Time: Sat May 25 05:01:08 EDT 2013
Powered by FUDForum. Page generated in 0.05799 seconds
