Home » Language IDEs » Java Development Tools (JDT) » Views information update(how to decide when to update view)
Views information update [message #943251] Sun, 14 October 2012 05:53 Go to next message
ben agai is currently offline ben agai
Member
hi.
i want to ask a question about the relationship between views like variables view
and debug events.
for example: if i debug a c program how does the variables view know when to update itself?, because it seems that even when the view is close and i click 'step into'
and reopen the view, the view presents the updated information.
so this is my question,how does the variables view (for instance)know when to update itself when a debug event occurs?
thanks for the help.
Re: Views information update [message #943566 is a reply to message #943251] Sun, 14 October 2012 12:31 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan Herrmann
VariablesView implements IDebugContextListener and as such it receives calls debugContextChanged(DebugContextEvent).
Have a look at the implementation of that method and you'll see how that relates to selection.
To see when this method is invoked I recommend the debugger Smile
HTH
Stephan
Re: Views information update [message #943748 is a reply to message #943566] Sun, 14 October 2012 15:07 Go to previous message
Member
thanks for the information, i have read the interface and the variables view implemention, but i didnt understand the uses of the IDebugContextListener interface nor the information i can get from the DebugContextEvent events.
can you pleas go into detail about that subject?,thanks.
Previous Topic:Publish failing for a Seam project
Next Topic:Reusing Interface Selection UI JDT
Current Time: Wed May 22 07:06:20 EDT 2013
Powered by FUDForum. Page generated in 0.01507 seconds
