| [Acceleo] Error launching main module as Acceleo Application [message #933114] |
Thu, 04 October 2012 14:50  |
Luís de Sousa Messages: 77 Registered: July 2009 |
Member |
Dear all,
I'm starting a new Acceleo project and whenever I try to launch a main module as an Acceleo application I get the following error in the log:
Quote:Message: Couldn't load class dsl3s.templates.Main from project DSL3S
Exception Stack Trace:
An exception stack trace is not available.
Session Data:
eclipse.buildId=M20110909-1335
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product -data /media/Data/users/lads/Trabalho/Eclipse/Workspace.DSL3S -product org.eclipse.epp.package.java.product
This happens with all main modules in the project. I have verified that all packages containing main modules are exported in the MANIFEST file.
I understand there is little information here. How can I provide more useful details?
Thank you,
Luís
| Re: [Acceleo] Error launching main module as Acceleo Application [message #966864 is a reply to message #942142] |
Thu, 01 November 2012 05:49  |
Member |
My apologies for the belated response.
Ed Willink wrote on Sat, 13 October 2012 03:01Hi
Your line looks extremely suspect:
"New.common" is not an extension such as "*.common".
New.common.Test.this is unlikely to be a Resource Factory.
So you can probably delete the line because it does nothing.
Actually the template started running after including that, so it might do something after all...
In any case, given the project I attached here, what would be the correct content of this line?
Thank you.
FUDForum. Page generated in 0.01860 seconds
