Home » Language IDEs » CDT » Help setting CDT Indexer include path programmatically(How to add include path to CDT indexer programmatically to avoid source annotations in Editor)
Help setting CDT Indexer include path programmatically [message #821762] Thu, 15 March 2012 15:46 Go to next message
Presanna Raman is currently offline Presanna Raman
I am new to developing using CDT plug-in. I am currently using Eclipse Indigo to develop my plug-in. I was planning on making use of the features automatically available with CDT - content assist, error reporting, etc. But CDT always reports syntax errors - "Type '<Variable>' could not be resolved" and annotates the source for all definitions and variables unless they are defined in the same source file. This makes code readability very difficult. The project build successfully as it has its own build files where the Include path is correctly referenced..
I presume that this is due to the CDT indexer not having all the include paths available to it. I want to know how I can provide CDT with the include paths programmatically. It is not possible to provide the include paths via preferences as there are a lot of modules and they change across projects.
I looked online for a way to programmatically set the include path but I was not able to find any help or instructions. Any help with this will be appreciated.
With Regards,
Presanna Raman.
P.S. I have attached image of what I see in the editor. Note: The INT32 macro is resolved while the rest are not.
Re: Help setting CDT Indexer include path programmatically [message #821830 is a reply to message #821762] Thu, 15 March 2012 17:46 Go to previous messageGo to next message
I further searched online and found code similar to the following. But it does not seem to help me with setting the project Include path.
		ICProjectDescription projectDescription = CoreModel.getDefault().getProjectDescription(project);
	        ICConfigurationDescription activeConfiguration = projectDescription.getActiveConfiguration();
	        ICFolderDescription folderDescription = activeConfiguration.getRootFolderDescription();
	        ICLanguageSetting[] languageSettings = folderDescription.getLanguageSettings();
	        int id = 0;
	        for(int i=0; i<languageSettings.length; i++) {
	            String langId = languageSettings[i].getLanguageId();
	            if(langId.contains("org.eclipse.cdt.core.gcc")) {
	                id = i;
	                break;
	        ICLanguageSetting lang = languageSettings[id];
	        		//lang.setSettingEntries(ICSettingEntry.INCLUDE_PATH, enryList)
	        lang.setSettingEntries(ICSettingEntry.INCLUDE_PATH, lse);
	        projectDescription.setActiveConfiguration(activeConfiguration);
	        projectDescription.setCdtProjectCreated();
	        CoreModel.getDefault().getProjectDescriptionManager().setProjectDescription(project, projectDescription);
What I am doing wrong? I tried to find what each of these classes mean but I am having difficulty finding helpful documentation.
With Regards,
Presanna Raman.
Re: Help setting CDT Indexer include path programmatically [message #829510 is a reply to message #821830] Mon, 26 March 2012 07:41 Go to previous messageGo to next message
Slavian Petrov is currently offline Slavian Petrov
Hi Raman,
I have a similar issue with my plugin.
After a search in the CDT sources I found something that is working for me in:
Project: org.eclipse.cdt.ui
Class: org.eclipse.cdt.internal.ui.wizards.settingswizards#readSettings()
This is finally how I made it:
IProject project = ...
ICProjectDescription projectDescription = CoreModel.getDefault().getProjectDescription(project, true);
ICConfigurationDescription configDecriptions[] = projectDescription.getConfigurations();
for (ICConfigurationDescription configDescription : configDecriptions) {
	ICFolderDescription projectRoot = configDescription.getRootFolderDescription();
	ICLanguageSetting[] settings = projectRoot.getLanguageSettings();
	for (ICLanguageSetting setting : settings) {
		if (!"org.eclipse.cdt.core.g++".equals(setting.getLanguageId()))
			continue;
		List<ICLanguageSettingEntry> includes = new ArrayList<ICLanguageSettingEntry>();
		includes.addAll(setting.getSettingEntriesList(ICSettingEntry.INCLUDE_PATH));
		includes.add(new CIncludePathEntry("/my/local/include/path", ICSettingEntry.LOCAL));
		setting.setSettingEntries(ICSettingEntry.INCLUDE_PATH, includes);
CoreModel.getDefault().setProjectDescription(project, projectDescription);
[Updated on: Mon, 26 March 2012 07:56]
Report message to a moderator
Re: Help setting CDT Indexer include path programmatically [message #941103 is a reply to message #829510] Fri, 12 October 2012 04:10 Go to previous messageGo to next message
TBT Andrew is currently offline TBT Andrew
I am also developing a eclipse plugin to write include paths programmatically. I used the above code.
But the C/C++Build->Paths&Symbols does not update with the new data.
When access the data using setting.getsettingEntries() I can see the newly added data. But can't see in the properties window or
in project explorer.
Re: Help setting CDT Indexer include path programmatically [message #941287 is a reply to message #941103] Fri, 12 October 2012 07:15 Go to previous messageGo to next message
Hi TBT Andrew,
I made a mistake in the code above - bad if (...)
This is how I made it finally:
if (!setting.getId().startsWith("cdt.managedbuild.tool.gnu.cpp.compiler"))
continue;
Re: Help setting CDT Indexer include path programmatically [message #1015765 is a reply to message #941287] Sat, 02 March 2013 08:13 Go to previous messageGo to next message
Krishnaraj Bhat is currently offline Krishnaraj Bhat
Hi Slavian Petrov,
I am developing an eclipse plugin. I want to add the include paths programmatically when creating a new project. I am not sure about where to include the piece of code mentioned in the above posts. Could you please let me know the point where should this code be initiated.
Krishnaraj.
Re: Help setting CDT Indexer include path programmatically [message #1019112 is a reply to message #821762] Fri, 15 March 2013 00:03 Go to previous messageGo to next message
Hi Raman,
Could you please let me know where should I write the piece of code mentioned by you so that new projects created will include the "INCLUDE PATHS".
Krishnaraj.
Re: Help setting CDT Indexer include path programmatically [message #1019113 is a reply to message #1015765] Fri, 15 March 2013 00:05 Go to previous message
No Message Body
Previous Topic:C++ Makefile project issues
Next Topic:Import C++ project from SVN
Current Time: Sun May 26 05:08:39 EDT 2013
Powered by FUDForum. Page generated in 0.01785 seconds
