| Possibility to generate Circular Referenced target model [message #941147] |
Fri, 12 October 2012 04:45  |
Alexander Unsonamed Messages: 10 Registered: October 2012 |
Junior Member |
Is it possible to somehow handle Circular References?
My source model has circular references, and I'd like to have circular references in generated target model.
E.g.:
result.name := "Model";
var box: Box := object Box {
name := "Box node";
var subBox : Box := object Box {
name := "SubBox";
result.root := box;
box.children += subBox;
subBox.children += box;
So, I have Box with child of type Box. Thus I have possibility to create infinite nesting of boxes.
As a result of transformation, I have result object without any children.
If I remove the following statement:
transformation works well, but I get predefined 1-level nesting.
| Re: Possibility to generate Circular Referenced target model [message #941208 is a reply to message #941147] |
Fri, 12 October 2012 05:46   |
Ed Willink Messages: 3183 Registered: July 2009 |
It's certainly possible, but QVTo is only partially declarative so you
need to empathize with its imperative actions.
A circular loop cannot naturally be created in a single regular pass.
Rather than ensuring the referential validity of each loop step and
having a special loop closing step, I recommend what I usually find
necessary in QVTo; code in two passes.
Pass 1 creates the output as a tree, and populates an in2out Dict.
Pass 2 adds cross-references to the tree using the in2out Dict from pass 1.
[If you're clever/lucky you can use 'resolve' in place of the Doct, but
I find resolve hard to understand/debug in practice.]
Ed Willink
> E.g.:
> name := "Box node";
> name := "SubBox";
> result.root := box;
| Re: Possibility to generate Circular Referenced target model [message #944881 is a reply to message #944828] |
Mon, 15 October 2012 02:32  |
Take the simplest of trees with links
A
B, link to C
C, link to B
This can be constructed in containment order
create A
create B
create C
then crossreferenced
assign B link to C
assign C link to B
since when assigning cross references all sources and targets exist.
Cannot be done in one pass.
If A, B, C result from a transformation on a, b, c then in2out Dict contains
a => A
b => B
c => C
Ed Willink
On 15/10/2012 07:03, Alexander Unsonamed wrote:
> Quote:
>> pass 1.
> Thanks for the comment, but I really don't understand what you meant
> by in2out Dict. What am I supposed to store in such a dictionary and
> why it cannot be created by one pass?
> Can you supply me with the simplest example, it would be nice.
> Thanks in advance.
FUDForum. Page generated in 0.07437 seconds
