Home » Newcomers » Newcomers » Problem to start eclipse(I made backup and won't start.)
Problem to start eclipse [message #940683] Thu, 11 October 2012 17:55
Paulo Kutwak is currently offline Paulo Kutwak
I have problem to start Eclkipse. My Windows xp Pro was with problems, so I needed to format and reinstall again. Before, I made backup of Eclipse folder with all plugins. I copied back to hd and I try to start the Eclipse, but always give error. I copy with was before, I don't made any change.
The log with error.
!SESSION 2012-10-08 15:12:40.843 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.7.0_07
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_BR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2012-10-08 15:12:42.046
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of bundle org.eclipse.equinox.simpleconfigurator.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalArgumentException: invalid version "1 com.ibm.icu,4.4.2.v20110823,plugins/com.ibm.icu_4.4.2.v20110823.jar,4, true com.jcraft.jsch,0.1.46.v201205102330,plugins/com.jcraft.jsch_0.1.46.v201205102330.jar,4, true": non-numeric "1 com"
at org.osgi.framework.Version.parseInt(Version.java:170)
at org.osgi.framework.Version.<init>(Version.java:126)
at org.eclipse.equinox.internal.simpleconfigurator.utils.SimpleConfiguratorUtils.parseCommentLine(SimpleConfiguratorUtils.java:123)
at org.eclipse.equinox.internal.simpleconfigurator.utils.SimpleConfiguratorUtils.readConfiguration(SimpleConfiguratorUtils.java:71)
at org.eclipse.equinox.internal.simpleconfigurator.utils.SimpleConfiguratorUtils.readConfiguration(SimpleConfiguratorUtils.java:41)
at org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:52)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:129)
at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:143)
at org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:48)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 12 more
Caused by: java.lang.NumberFormatException: For input string: "1 com"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at org.osgi.framework.Version.parseInt(Version.java:168)
... 23 more
Root exception:
... 23 more
!ENTRY org.eclipse.osgi 4 0 2012-10-08 15:12:42.062
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744 [1] is not active.
!ENTRY org.eclipse.osgi 4 0 2012-10-08 15:12:42.093
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Previous Topic:Problem plugin after update
Next Topic:Adopt Eclipse in E-Learning Platform
Current Time: Wed May 22 01:57:10 EDT 2013
Powered by FUDForum. Page generated in 0.05061 seconds
