Home » Modeling » EMF » [CDO] Changes between the 4.1 releases?
[CDO] Changes between the 4.1 releases? [message #940647] Thu, 11 October 2012 17:12 Go to next message
Warwick Burrows is currently offline Warwick Burrows
Member
How can I tell what changes have been made between each of the 4.1 releases. I picked up what was the last RC for CDO 4.1 have been working with and deployed that build. Now I'd like to see what fixes and features have been added to 4.1 SR1.
Warwick
Re: [CDO] Changes between the 4.1 releases? [message #941070 is a reply to message #940647] Fri, 12 October 2012 03:33 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 11.10.2012 23:12, schrieb Warwick Burrows:
> SR1.
Our download page shows the release notes per drop, e.g.,
http://download.eclipse.org/modeling/emf/cdo/drops/R20120612-1449/relnotes.html for the 4.1 release. This year our SR1
release is not much different from 4.1 release because the team has effectively shrinked a lot. I did do quite some
maintenance in the 4.2 stream (master branch). If you find fixes there I'm willing to port them back on demand.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Changes between the 4.1 releases? [message #941081 is a reply to message #941070] Fri, 12 October 2012 03:50 Go to previous message
Member
Ok that explains it Smile A lot of good work by you guys went into to the 4.1 release. I picked up what I believe was the final candidate before the 4.1 release: RC4 and its going well. I've bumped into an ocl query issue (no reverse sort) and was checking to see if there was a related fix between RC4 and the 4.1 SR1.
Warwick
Previous Topic:[XCore] ChildCreationExtenders and ExtensibleProviderFactory issue
Next Topic:[CDO/Hibernate] NOT NULL constraint on EReference with EOpposite
Current Time: Tue May 21 06:07:56 EDT 2013
Powered by FUDForum. Page generated in 0.01658 seconds
