Home » Eclipse Projects » EclipseLink » Moxy JPA+JAXB mapping issue with list unwrapping(Moxy JPA+JAXB mapping issue with list unwrapping)
Moxy JPA+JAXB mapping issue with list unwrapping [message #938979] Wed, 10 October 2012 06:15 Go to next message
Mark Jones is currently offline Mark Jones
Hi I am struggling to create a mapping from my JPA object to my targeted xml schema.
My main class structure is as follows for brevity -:
Project {
   private Set<ProjectAbstract> projectAbstracts = new HashSet<ProjectAbstract>(0);
ProjectAbstract {
    private String abstract;
    private String fooAttribute;
I desire this output.
<project>
<abstract fooAttribute="foo">abstract text</abstract>
</project>
I have tried XMLAdaptor, XmlPath and numerous approaches but I cannot unwrap the set and end up with (or similar) -:
<project>
<ProjectAbstracts>
</ProjectAbstracts>
</project>
I have literally hundreds of classes so creating a full set of JAXB bindings and mapping code really isn't much of an option!
Maybe my XMLadaptor is incorrect but I cant see how to make it accept Collections and work in the way I desire.
EDIT: I have switched to the latest Moxy to try and achieve this
[Updated on: Wed, 10 October 2012 06:16]
Report message to a moderator
Re: Moxy JPA+JAXB mapping issue with list unwrapping [message #939185 is a reply to message #938979] Wed, 10 October 2012 09:58 Go to previous messageGo to next message
Blaise Doughan is currently offline Blaise Doughan
Below I'll demonstrate how you can map your use case without an XmlAdapter or any of MOXy's extensions such as @XmlPath.
Project
package forum398114;
import java.util.*;
import javax.xml.bind.annotation.*;
@XmlRootElement
@XmlAccessorType(XmlAccessType.FIELD)
public class Project {
	@XmlElement(name="abstract")
Project Abstract
public class ProjectAbstract {
    @XmlValue
    private String abstractValue;
    @XmlAttribute
jaxb.properties
This example will work with any JAXB (JSR-222) implementation. To specify MOXy as your JAXB provider you need to include a file called jaxb.properties in the same package as your domain model with the following entry (see: http://blog.bdoughan.com/2011/05/specifying-eclipselink-moxy-as-your.html).
javax.xml.bind.context.factory=org.eclipse.persistence.jaxb.JAXBContextFactory
Demo
import java.io.File;
import javax.xml.bind.*;
public class Demo {
	public static void main(String[] args) throws Exception {
		JAXBContext jc = JAXBContext.newInstance(Project.class);
		Unmarshaller unmarshaller = jc.createUnmarshaller();
		File xml = new File("src/forum398114/input.xml");
		Project project = (Project) unmarshaller.unmarshal(xml);
		Marshaller marshaller = jc.createMarshaller();
		marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
		marshaller.marshal(project, System.out);
input.xml/Output
Below is the input to, and output from running the demo code:
<project>
</project>
For More Information
The following articles provide additional information on the topics used in this post.
- http://blog.bdoughan.com/2011/06/jaxb-and-complex-types-with-simple.html
- http://blog.bdoughan.com/2010/09/jaxb-collection-properties.html
Re: Moxy JPA+JAXB mapping issue with list unwrapping [message #939545 is a reply to message #939185] Wed, 10 October 2012 17:29 Go to previous messageGo to next message
Thanks very much, it worked exactly as I asked.
Is it possible to take the attribute from a third level class. I am unable to make it work.
Project {
ProjectAbstract {
    private ISO639Lang language;
ISO639Lang {
private String ISO639LangCode;
I am using this on my package-info.java as I only require a few thousand xml elements within my much larger JPA model.
@XmlAccessorType(XmlAccessType.NONE)
<project>
<abstract ISO639LangCode="foo">abstract text</abstract>
</project>
I could maybe do with some sort of pass through annotation so that the Object is followed but not added to the xml, only its children -:
Or should I use an adaptor? I am trying to avoid this though due to the number of elements I have.
ProjectAbstract {
    @XMLEvaluateSubelements
ISO639Lang {
@XmlAttribute
I particularly appreciate your time as project lead spending time on the forums.
Re: Moxy JPA+JAXB mapping issue with list unwrapping [message #939573 is a reply to message #939545] Wed, 10 October 2012 18:10 Go to previous messageGo to next message
Here is my working adaptor example that mixes the attribute and adaptor annotations for the desired effect. However a solution without an adaptor would be great. Thanks.
ProjectAbstract {
@XmlValue
@XmlJavaTypeAdapter(ISO639LangAdaptor.class)
@XmlAttribute(name="cfLangCode")
ISO639Lang {
@XmlAttribute
ISO639LangAdaptor {
public String marshal(ISO639Lang v) throws Exception {
return v.getISO639LangCode();
Re: Moxy JPA+JAXB mapping issue with list unwrapping [message #940289 is a reply to message #938979] Thu, 11 October 2012 09:56 Go to previous messageGo to next message
The good news is that this can be done without the use of an XmlAdapter. I'll demonstrate below with an example.
Project
import java.util.*;
@XmlRootElement
ProjectAbstract
We will map the field/property of type ISO639Lang as an @XmlAttribute. We can do this if that class has one mapping of type @XmlValue.
	@XmlValue
	@XmlAttribute(name="ISO639LangCode")
ISO639Lang
This class has one mapping of type @XmlValue.
public class ISO639Lang {
	@XmlValue
Demo
public class Demo {
input.xml/Output
<project>
</project>
Re: Moxy JPA+JAXB mapping issue with list unwrapping [message #940593 is a reply to message #940289] Thu, 11 October 2012 15:50 Go to previous message
Hi thanks again. This worked on the test case but failed on my code.
Some sleuthing revealed this was down to JPA bytecode manipulation as I am using lazy fetching and the OSIV pattern for this read only part of the code. So far even during fairly complex documents the only error point was at -:
@XmlValue private String ISO639LangCode;
As have hundreds of entities and countless thousands of JPA fields so I am trying to keep the annotations to a minimum otherwise I will be chasing small xml output bugs for the rest of my life.
Is there some way around this?
Could JPA or JAXB be forced into a different mode for example?
EDIT: I have solved this annotating on the property works.
Thanks again.
[Updated on: Thu, 11 October 2012 16:24]
Previous Topic:maven repo problem
Next Topic:Memory leak issue
Current Time: Sun May 19 05:27:14 EDT 2013
Powered by FUDForum. Page generated in 0.02080 seconds
