Home » Eclipse Projects » Eclipse 4 » Part actionbar contributor
Part actionbar contributor [message #939268] Wed, 10 October 2012 11:29 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising name
I would like to add few actions/handelers specific to a inputpart. In 3.x we used to define actionbarcontributor class in editor declaration which use to add actions to tool bar and to menu bar.
How can i achieve the same effect in eclipse 4?
Re: Part actionbar contributor [message #939273 is a reply to message #939268] Wed, 10 October 2012 11:35 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
the question is if you need to do it programmatically or if it can be done within the Application Model.
For the last one you can open the Application Model Editor, open your Part, enable the Toolbar (there is a checkbox I searched myself today Smile ). After that you are able to add HandledToolItems to your part specific toolbar.
Hope that helps,
Dirk
Re: Part actionbar contributor [message #939333 is a reply to message #939273] Wed, 10 October 2012 12:55 Go to previous messageGo to next message
thanks!
actually i forgot to mention, i want to do it programmatically.
any idea?
Re: Part actionbar contributor [message #939375 is a reply to message #939333] Wed, 10 October 2012 13:58 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
As Dirk mentioned, first figure out how to do it using the model editor. Everything in the model editor is done by manipulating an EMF model, so you can do the same steps in code. The only trick is to figure out which factory you need to create the different objects (E4 has just shy of a dozen, i believe) -- the factories are all in org.eclipse.e4.ui.model.workbench and are named something like M*Factory.
Brian.
Re: Part actionbar contributor [message #940007 is a reply to message #939375] Thu, 11 October 2012 04:19 Go to previous messageGo to next message
I'm not sure if this is the preferred way as I'm quite new to Eclipse 4, but for adding items to a part toolbar I've found the following.
The Eclipse 4 Application model is a dynamic model. So you can add/remove/modify everything at runtime.
As Brian said, there are some factory classes that help on creating new model elements.
With the help of the EModelService you are able to find model elements that you want to modify.
The following code will search for a part in the application model and add a toolbar with one item to the part. It is in the constructor of the part to modify.
@Inject
public MyPart(MApplication application, EModelService service) {
	List<MPart> parts = service.findElements(application, ID, MPart.class, null);
	if (parts != null && !parts.isEmpty()) {
		MPart myPart = parts.get(0);
		//create the toolbar programmatically
		MToolBar toolbar = MMenuFactory.INSTANCE.createToolBar();
		//create the tool item programmatically
		MDirectToolItem element = MMenuFactory.INSTANCE.createDirectToolItem();
		element.setElementId("myToolItemId");
		element.setIconURI("platform:/plugin/myBundle/icons/someicon.gif");
		element.setContributionURI("bundleclass://myBundle/myBundle.handler.MyTestHandler");
		element.setVisible(true);
		element.setEnabled(true);
		toolbar.getChildren().add(element);
		myPart.setToolbar(toolbar);
Making programmatical contributions to the menu of the window should work in a similar way, but you need to find the window menu bar instead of the part toolbar.
Hope it works for you and this is really the Eclipse 4 way to do so. Smile
Greez,
Dirk
Re: Part actionbar contributor [message #940029 is a reply to message #940007] Thu, 11 October 2012 04:47 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
You can also inject the MPart in the @PostConstruct method of the part so you don't have to do the searching. Create a method annotated with @PostConstruct and put a MPart p argument on it. After that do with p what Dirk did with myPart.
Re: Part actionbar contributor [message #940284 is a reply to message #940029] Thu, 11 October 2012 09:53 Go to previous messageGo to next message
thank you so much for assistance.
I would like to add contribution to main tool bar. For example normally we have print/copy/ save etc buttons on tool bar and when some editor is activated and selected they can be enabled. But if editor is not selected then they are not enabled. I have done that in eclipse 3.x using actions. I had editor and use to register action in action registry of editor and EditorActionBarContributor class use to build actions.
I would like to achieve similar functionality in 4x.
Any idea?
Cheers
Re: Part actionbar contributor [message #940298 is a reply to message #940284] Thu, 11 October 2012 10:05 Go to previous message
There is the annotation @CanExecute where you define whether a command es enabled or disabled.
There is the annotation @Active which can be used to inject the current active part
@CanExecute
public void canExecute(@Active MPart part) {
//fancy code that checks if this is the part for which the handler should be active
This will brings us back to the model solution. Define your handlers in the application model, add them to the main menu and implement the @CanExecute properly.
Greez,
Dirk
Previous Topic:org.eclipse.core.runtime.AssertionFailedException
Next Topic:Icon size in Part toolbar
Current Time: Sun May 19 01:13:43 EDT 2013
Powered by FUDForum. Page generated in 0.06205 seconds
