| [SOLVED] Jubula and eclipse 3.7 [message #849908] |
Thu, 19 April 2012 11:11  |
Ryan Goetz Messages: 4 Registered: April 2012 |
Junior Member |
Does Jubula support applications that are written with Eclipse 3.7.
If they do we can't get the start 'observation mode' to appear when Jububla opens the application up. We added the rcp plugin to the plugin directory under our application, and use 'rcp' mode for the AUT.
steps
Create new project
specify a new aut with rcp toolkit
unzip rcp-support.zip
took .jar and added to my programs plugins folder
started autagent
connect aut to autagent
jubula loads my application
the 'observation mode' is still greyed out and the progress says that aut is opening application even though the application is already open
Ryan
[Updated on: Fri, 20 April 2012 17:17] Report message to a moderator
| Re: Jubula and eclipse 3.7 [message #851276 is a reply to message #849908] |
Fri, 20 April 2012 16:46   |
Junior Member |
Thanks that worked
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Mon Feb 13 13:52:35 PST 2012
org.eclipse.update.reconcile=false
org.eclipse.ui/LOCK_TRIM=true
eclipse.p2.profile=profile
osgi.framework=file\:plugins/org.eclipse.osgi_3.7.1.R37x_v20110808-1106.jar
equinox.use.ds=true
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.200.v20110502-1955.jar@1:start,\
org.eclipse.update.configurator@3:start,\
org.eclipse.jubula.rc.rcp@start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=gov.nasa.arc.irg.spheres.workbench.comms.SpheresWorkbenchCommsProduct
osgi.splashPath=platform\:/base/plugins/gov.nasa.arc.irg.spheres.workbench.comms
osgi.framework.extensions=
osgi.bundles.defaultStartLevel=4
eclipse.application=gov.nasa.arc.irg.spheres.workbench.comms.application
eclipse.p2.data.area=@config.dir/../p2
[Updated on: Fri, 20 April 2012 17:16] Report message to a moderator
| Re: Jubula and eclipse 3.7 [message #940059 is a reply to message #851276] |
Thu, 11 October 2012 05:17  |
Romain Marzat Messages: 1 Registered: October 2012 |
Junior Member |
i can update this post because i currently have the same problem. Indeed, when i run the application i want to test, the Start Observation Mode icon stay greyed. I followed the documentation i have found and i added this line at the end of osgi.bundle : org.eclipse.jubula.rc.rcp
After that, i have nothing more than what i had before. Can you help me ?
Thanks a lot.
FUDForum. Page generated in 0.01544 seconds
