Home » Eclipse Projects » BIRT » Use Multiple Dataset For One Table
Use Multiple Dataset For One Table [message #935154] Sat, 06 October 2012 14:54 Go to next message
Utkarsh Shinde is currently offline Utkarsh Shinde
I have issue in BIRT
I have two datasets I have to use both of them in one table how's it possible
Query of dataset1:
SELECT
HC.CASE_NO CASE_NO,
HC.NO_REVIEWS NO_REVIEWS,
RP.case_status_id rvw_prd_status,
HUSR0201_RPT.AWAITING_DECISION_CASE_PROD(HC.CASE_NO) CASE_PROD2,
HUSR0201_RPT.AWAITNG_DECISN_CASE_INCDNT_NO(HC.CASE_NO) CASE_INCDNT_NO2,
HUSR0201_RPT.AWAITNG_DECISN_ms_user(HC.CASE_NO) ms_user2,
HUSR0201_RPT.AWAITNG_DECISN_CASE_RVW_NO(HC.CASE_NO) case_rvw_no,
HUSR0201_RPT.AWAITNG_DECISN_RECEIVED_DATE(HC.CASE_NO) STATUS_DATE2,
HUSR0201_RPT.AWAITNG_DECISN_AP_CONT_ATT_RN(HC.CASE_NO) AP_CONT_ATT_RN,
HUSR0201_RPT.PEER_TO_PEER_CONTACT_DATE(HC.CASE_NO) LAST_AP_CONT_RN,
HUSR0201_RPT.REFERRAL_TYPE_ID(HC.CASE_NO) referral_type_id,
HUSR0201_RPT.GET_PATIENT_L(HUSR0201_RPT.AWAITNG_DECISN_CASE_INCDNT_NO(HC.CASE_NO)) LNAME,
HUSR0201_RPT.GET_PATIENT_F(HUSR0201_RPT.AWAITNG_DECISN_CASE_INCDNT_NO(HC.CASE_NO)) FNAME,
HUSR0201_RPT.GET_CLIENT_CN(HUSR0201_RPT.AWAITNG_DECISN_CASE_INCDNT_NO(HC.CASE_NO)) CLIENT_NAME,
HUSR0201_RPT.GET_CLIENT_ON(HUSR0201_RPT.AWAITNG_DECISN_CASE_INCDNT_NO(HC.CASE_NO)) ORG_NAME,
HUSR0201_RPT.GET_RVW_PRD_DATE(HUSR0201_RPT.AWAITNG_DECISN_CASE_RVW_NO(HC.CASE_NO),HC.CASE_NO) RECVD_DATE,
HUSR0201_RPT.GET_LOCATION(HUSR0201_RPT.AWAITNG_DECISN_MS_USER(HC.CASE_NO)) LOC_NO,
HUSR0201_RPT.GET_LOCATION_TN(HUSR0201_RPT.AWAITNG_DECISN_ms_user(HC.CASE_NO)) team_no
from case_rvw_period RP, hcx_case HC
where HC.inq_ind = 'N'
and HC.closed_id is NULL
and nvl(HC.ms_id, HC.rn_id) is not NULL
and HC.case_prod in ('OPR','PTR','CHR')
and RP.case_no = HC.case_no
AND RP.CASE_RVW_NO = HC.NO_REVIEWS
AND RP.CASE_STATUS_ID NOT IN ('CERT','CLTR','CMPL','DENY','OVER','UPHD')
ORDER BY 5
and
Query for dataset2:
select count(HC.ms_id) as total_user from HCX_CASE HC,case_rvw_period RP
group by ms_id having (count(ms_id)>=1)
I want to put total_user to same table which have already columns from dataset1
I used Joined dataset but its not working.
pl suggest.
[Updated on: Sat, 06 October 2012 14:57]
Report message to a moderator
Re: Use Multiple Dataset For One Table [message #937334 is a reply to message #935154] Mon, 08 October 2012 18:30 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
If data set two only returns one row you could always add it to the top of the report and use the visibility rule to hide the table. Then in the oncreate for the data item you could add a script like:
reportContext.setPersistentGlobalVariable("myave",this.getValue());
You could then get this value later(second table) like:
reportContext.getPersistentGlobalVariable("myave"); //this can be called from an expression or from a report item script. You could also call it from chart script like:
function beforeGeneration( chart, icsc )
var mytitle = "Avg QTY for Order is: " +icsc.getExternalContext().getScriptable().getPersistentGlobalVariable("myave");
chart.getTitle().getLabel().getCaption().setValue(mytitle);
If you are going to manipulate this value further (ie use it in a calculation you may have to set it as a type when you save it) ie
//save it
importPackage(Packages.java.lang);
reportContext.setPersistentGlobalVariable("myave",new Integer(this.getValue()));
//use it
var myval =parseInt(reportContext.getPersistentGlobalVariable("myave"));
see example report attached.
Jason
  • Attachment: total.zip
    (Size: 5.92KB, Downloaded 64 times)
Jason Weathersby
BIRT Exchange
Re: Use Multiple Dataset For One Table [message #937730 is a reply to message #937334] Tue, 09 October 2012 04:06 Go to previous messageGo to next message
I want total_user(actually it is total_cases) in Parallel of other Columns...pl look Screenshot.total_case in Screenshot.I have to count cases for Each User.other columns from query1.
Re: Use Multiple Dataset For One Table [message #938293 is a reply to message #937730] Tue, 09 October 2012 14:46 Go to previous messageGo to next message
Does total_cases change for every row? If so you could use a nested table.
Here is an older example:
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1/subreport/index.php
Jason
Jason Weathersby
BIRT Exchange
Re: Use Multiple Dataset For One Table [message #939311 is a reply to message #938293] Wed, 10 October 2012 12:34 Go to previous messageGo to next message
yes total_case changes for every row.nested table not working there.
Re: Use Multiple Dataset For One Table [message #939860 is a reply to message #939311] Thu, 11 October 2012 01:09 Go to previous message
Do you get an error? What does the output look like?
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Looking for Excel Emitters
Next Topic:Issue with editing
Current Time: Sat May 25 17:47:01 EDT 2013
Powered by FUDForum. Page generated in 0.05416 seconds
