Home » Eclipse Projects » Jubula » Jubula autrun and autid
Jubula autrun and autid [message #932703] Thu, 04 October 2012 06:52 Go to next message
Sascha Mising name is currently offline Sascha Mising name
I need some guidance.
I give the process "autrun.exe" the parameter "-i EclipseSUTTFS" (= AUTID).
The Testexec uses a xml config file which has the parameter "<autid>EclipseSUTTFS</autid>"
Also I entered the ExlipseSUTTFS in the Properties Dialog of the AUT "AUT IDs for AUTs started with the autrun option.
The Testrun is sucsessful.
BUT
If i look into the "test Result Summary" View the AUT ID of these testruns is ALWAYS reported as "autrun".
Am I missing something or is this a bug ?
Thanks Sascha
Re: Jubula autrun and autid [message #937973 is a reply to message #932703] Tue, 09 October 2012 08:26 Go to previous messageGo to next message
Can anybody reproduce this behaviour ?
Re: Jubula autrun and autid [message #939410 is a reply to message #937973] Wed, 10 October 2012 14:34 Go to previous message
Alejo Abdala is currently offline Alejo Abdala
Hi, I'm using the same setup as you (though passing the AUT id to testexec via param, not config file), and this is what I get in the test report:
Application Under Test
Name AUT MuleStudio
Configuration autrun
You get 'autrun' on both fields, name and configuration? If you do, maybe you could try passing the aut id through parameter instead of the config file, at least it works for me.
Cheers
Previous Topic:Starting RCP with workspace: autrun.exe and -data option
Next Topic:Using multiple users with Oracle XE
Current Time: Sun May 26 03:31:58 EDT 2013
Powered by FUDForum. Page generated in 0.01793 seconds
