| I want to do profiling of an ear project rnning on JBOSS 5.1 usng TPTP [message #938961] |
Wed, 10 October 2012 05:59  |
Himadri Khargharia Messages: 23 Registered: October 2012 |
Junior Member |
Java used is 1.6
I have followed all the steps mentioned in http://eclipse.org/t...ng_started.html
but whenever i am setting -agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf:execdetails=true in JAVA_OPTS it is giving "Could not find agent library on the library path or in the local directory: JPIBootLoader"
I have tried everything like setting the JAVA_PROFILER_HOME to JPIBootLoader in the environment variable, also like setting the path to it. But unable to remove this error.
Also in eclipse after running the AC Server or through Integrated Agent Controller, i am not able to see the agents in the attach to agents tag
Though i am able to do an eclipse application profiling, i am not able to profile the J2EE application running in JBOSS
Please note .. i will not be able to integrate the JBOSS with eclipse,we are using ant scripts to start our server and i have given the port as 11000
FUDForum. Page generated in 0.02249 seconds
