| Bpel model for CDO [message #937994] |
Tue, 09 October 2012 08:51  |
Francesco Guidieri Messages: 4 Registered: July 2009 |
Junior Member |
Hi all,
we are developing a custom model-oriented IDE that is based upon
different tecnologies of Eclipse.
Bpel Designer is one of these parts and it's used to create processes
that describe some logic interactions.
All the data about these 'parts' are modeled with EMF and stored in a
CDO server.
We would like to persiste bpel model in the same way.
(We are using bpel designer only as a modeler, we don't need the files
in the filesystem)
So, as you probably know, CDO needs a special code generation.
We tried to re-generate the Bpel model code, but we encountered a lot of
problems due to the lack of 'generated not' annotations.
So the question, is there any plan to review the model code?
Do you have any suggestions? Any comments by return will be much
appreciated.
Francesco
| Re: Bpel model for CDO [message #938937 is a reply to message #937994] |
Wed, 10 October 2012 05:37  |
Hi Francesco,
We don't have any plans at this time to update the BPEL model. If you can tell me some more specifics about what needs to be changed in the model (you mentioned a "lack of 'generated not' annotations?) it may be possible to make these changes relatively quickly. Failing that, is it possible for you to copy the BPEL ecore and modify it as necessary?
Cheers!
Bob
FUDForum. Page generated in 0.01466 seconds
