Home » Modeling » EMF Diff/Merge » How to compare unordered list
How to compare unordered list [message #921359] Sun, 23 September 2012 23:40 Go to next message
Oliver Zhou is currently offline Oliver Zhou
Member
Hi Author,
I think it should be quite common question.
Based on my own experiments, if the order of the element in unordered list is different in the two compared model even if the content of element are completely equal.
I think it may be the default behavior of EMF Compare.
I'm wondering how can I override this behavior?
Is it very hard to implement?
Best wishes,
Oliver
Re: How to compare unordered list [message #938902 is a reply to message #921359] Wed, 10 October 2012 05:01 Go to previous message
Olivier Constant is currently offline Olivier Constant
It seems your question is relative to EMF Compare, not EMF Diff/Merge.
The former is a full end-user solution, the latter is an engine for building tools that manipulate models by merge (although it provides a sample GUI).
I see that you have also posted on the EMF Compare forum so I guess it's fine.
Olivier
Previous Topic:EMF Diff/Merge is available!
Next Topic:Structural comparison of two model trees
Current Time: Tue May 28 21:00:54 EDT 2013
Powered by FUDForum. Page generated in 0.01585 seconds
