Home » Eclipse Projects » Rich Client Platform (RCP) » RCP Application based on Features
RCP Application based on Features [message #937937] Tue, 09 October 2012 07:52 Go to next message
Ar vraepe is currently offline Ar vraepe
Hello everyone,
I have been searching for a good example on Features. I successfully managed to create a simple basic feature and update site for an eclipse.
But now I want to create an RCP Application based on features. I've developped the application based on plug-ins and it works just fine! Could build everything... tested even with Delta Packs.
The next step would be to pack some plug-ins into features and create an update site for them to decorate my RCP Application... but these features are a bit more complex then most examples... and so I don't know what to do. I'm having these error messages as:
!MESSAGE Bundle reference:file:/C:/Eclipse Workspaces/SmartSignature/smartapps.smartsignature.templates.ui/ was not resolved.
!SUBENTRY 2 smartapps.smartsignature.templates.ui 2 0 2012-10-09 13:19:56.608
!MESSAGE Missing required bundle org.eclipse.ui.ide_3.7.0.
!MESSAGE Missing required bundle org.eclipse.wb.swt_1.0.0.
!MESSAGE Missing required bundle org.eclipse.core.filesystem_1.3.100.
!MESSAGE Missing required bundle org.eclipse.ui.editors_3.7.0.
which tells me that some plug-ins can't be found.. but when I add them to the feature it doesn't work either.. I have no idea where to put what in this structure... so I am looking for a good tutorial on this. I have followed some like the vogella tutorial and this one (ralfebert.de/blog/eclipsercp/p2_updates_tutorial_36/) but it didn't quite do the trick.
Are there any more examples available? Smile
Thank you
An example
My plug-in Management.UI has dependencies of org.eclipse.wb.swt and org.eclipse.ui.forms
but also org.eclipse.ui and org.eclipse.runtime... and these plug-ins are found.. but not the others.. why? how?
I get this message:
!MESSAGE Bundle reference:file:/C:/Eclipse Workspaces/SmartSignature/smartapps.smartsignature.management.ui/ was not resolved.
!SUBENTRY 2 smartapps.smartsignature.management.ui 2 0 2012-10-10 10:49:51.256
!MESSAGE Missing required bundle org.eclipse.ui.forms_3.5.101.
!MESSAGE Missing required bundle org.eclipse.wb.swt_0.0.0.
My Management Feature (Containing the ui part) looks like this
-> http: // i.imgur.com/Cs6BU.png (remove spaces)
It seems like he doesn't find the ui.forms... but the wb.swt is found and still gives me the error...
[Updated on: Wed, 10 October 2012 04:56]
Report message to a moderator
Re: RCP Application based on Features [message #937989 is a reply to message #937937] Tue, 09 October 2012 08:52 Go to previous messageGo to next message
Alexandra Niculai is currently offline Alexandra Niculai
Member
It might be possible using the new feature of Eclipse Juno "Add required in feature based product" (see this link, it's the 4th thing on the page)
http://download.eclipse.org/eclipse/downloads/drops4/R-4.2-201206081400/news/eclipse-news-part4.html
Re: RCP Application based on Features [message #938847 is a reply to message #937989] Wed, 10 October 2012 03:55 Go to previous messageGo to next message
Thanks for your response! And aren't there any good tutorials of how to do it for 3.7 ? Because the application is really missing plug-ins...
[Updated on: Wed, 10 October 2012 03:56]
Re: RCP Application based on Features [message #938938 is a reply to message #938847] Wed, 10 October 2012 05:38 Go to previous messageGo to next message
I have found the solution
My features were ok, but my required plug-ins in the run configuration weren't. I had no clue that you could just reconfig your launch the same way as with a plug-in based product. right click product -> run configs -> add required plug-ins -> apply -> run did the trick!
Now I can start with the real p2 functionality..
Re: RCP Application based on Features [message #962151 is a reply to message #938938] Sun, 28 October 2012 18:39 Go to previous message
Lars Vogel is currently offline Lars Vogel
This will not fix it, after the export your product will fail again. Better to fix the product configuration as described here: Eclipse Product Configuration and Deployment.
Previous Topic:Port 3.2 application to latest
Next Topic:Headless Build Environment
Current Time: Sat May 25 14:00:12 EDT 2013
Powered by FUDForum. Page generated in 0.23727 seconds
