Home » Modeling » Graphiti » Nesting diagrams(Nested graphiti diagrams)
Nesting diagrams [message #924193] Wed, 26 September 2012 11:48 Go to next message
Iain Whiteside is currently offline Iain Whiteside
I'm wanting to create graphiti diagrams with nested nodes (sub-graphs contained in nodes). I know this is possible because there is something similar on the project homepage: http://www.eclipse.org/graphiti/
Are there any case studies or examples out there that I could look at for inspiration? Or any documentation on the principles?
Thanks!
Re: Nesting diagrams [message #924787 is a reply to message #924193] Thu, 27 September 2012 01:57 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Iain,
the diagrams shown on the page use simple nesting of container shapes with
rectangles as GAs; they again contain other shapes/container shapes.
I understood your question so that you wanted to nest a diagram inside
another one. That's not possible, although the pictograms model used by
Graphiti would principially allow such things. Instead the nesting should be
done on container shape level.
HTH,
Michael
Re: Nesting diagrams [message #938457 is a reply to message #924787] Tue, 09 October 2012 18:29 Go to previous messageGo to next message
Hi, thanks for this. I have been able to place container shapes inside others at the 'diagram level'. By this I mean that by dragging from the palette to inside a parent (and the parent flashes red) I have achieved nesting.
I can't figure out how to do this programmatically, though. Can you give an instance of (or reference to) some code that will contain one shape inside another *if they both already exist*?
Thanks!
Re: Nesting diagrams [message #940208 is a reply to message #938457] Thu, 11 October 2012 08:13 Go to previous message
You can simply change the parent of the future inner shape to the desired
parent, that should be all (besides some layout and domain adaptations of
course).
Michael
Previous Topic:Active Shapes problem
Next Topic:Graphiti and RAP
Current Time: Sun May 19 01:06:08 EDT 2013
Powered by FUDForum. Page generated in 0.01683 seconds
