Home » Modeling » TMF (Xtext) » How to customize hover for imported elements ?
How to customize hover for imported elements ? [message #938230] Tue, 09 October 2012 13:28 Go to next message
Cristiano Gaviao is currently offline Cristiano Gaviao
I setup the hover for the elements of my DSL properly using these two classes:
MyDslEObjectDocumentationProvider
MyDslEObjectHoverProvider
I need to add hover for some elements that are imported by my dsl too.
I have tried to add an if in the getFirstLine method of MyDslEObjectHoverProvider, but its never reached. For any element of my dsl it is working right:
protected String getFirstLine(EObject o) {
	String label = qualifiedNameProvider.getFullyQualifiedName(o)
			.toString();
	if (o instanceof AnImportedElement)
		return myDslUtils.retrieveHoverFirstLineAnImportedElement(
				(AnImportedElement) o, label);
could someone point me what am I missing ?
thanks,
Cristiano
Re: How to customize hover for imported elements ? [message #938316 is a reply to message #938230] Tue, 09 October 2012 15:08 Go to previous message
Christian Dietrich is currently offline Christian Dietrich
you usually to this in the dsl that provides the elements.
never the less: you may have a look at org.eclipse.xtext.ui.editor.hover.DispatchingEObjectTextHover.getHoverInfo(EObject, ITextViewer, IRegion)
there you can see that the stuff is done language specific. and i might be a place to hook in.
~Christian
Previous Topic:Provide model at runtime
Next Topic:Get all nodes of a given grammar construct type
Current Time: Sat May 25 14:35:54 EDT 2013
Powered by FUDForum. Page generated in 0.01489 seconds
