Home » Eclipse Projects » Eclipse 4 » Programatically open a menu from menubar (Programatically open a menu from menubar )
Programatically open a menu from menubar [message #938079] Tue, 09 October 2012 10:26 Go to next message
Somesh Rathi is currently offline Somesh Rathi
MenuManager and Menu Contribution items has been already created.
For the input Menu Item id , i need to programatically drop-down/open/display a menu item from menubar in eclipse.
I think i may need to fire some event.
Can you please help at the earliest.
Re: Programatically open a menu from menubar [message #941212 is a reply to message #938079] Fri, 12 October 2012 05:50 Go to previous message
Sopot Cela is currently offline Sopot Cela
Supposing you are using e4, take a look at the static updateElementVisibility method in the MenuManagerRendererFilter as the logic lies there. You can try and adapt it to your needs.
Previous Topic:GEF Editor in eclipse 4
Next Topic:Programmatically show a part
Current Time: Tue May 21 17:49:08 EDT 2013
Powered by FUDForum. Page generated in 0.01547 seconds
