Home » Eclipse Projects » Eclipse 4 » Main menu
Main menu [message #937956] Tue, 09 October 2012 08:08 Go to next message
Gennady Gromov is currently offline Gennady Gromov
Hello!
How to change the main menu of Trimmed window to another main menu programmically?
I created this another menu (with id:"menu:org.eclipse.ui.main.menu") in Menu Contributions section of Application.e4xmi and tried to set it by MTrimmedWindow.setMainMenu() method. But there is no result.
Which is right way to do this?
[Updated on: Tue, 09 October 2012 08:18]
Report message to a moderator
Re: Main menu [message #938021 is a reply to message #937956] Tue, 09 October 2012 09:34 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
Is the new menu you supply set to be rendered?
Re: Main menu [message #938955 is a reply to message #938021] Wed, 10 October 2012 05:52 Go to previous message
I tried both variants of "to be rendered". After the execution the setMainMenu() method the previous menu is still visible but don't works.
Previous Topic:Using own TranslationService for Application.e4xmi
Next Topic:Blog: Why Eclipse e4
Current Time: Thu May 23 15:05:53 EDT 2013
Powered by FUDForum. Page generated in 0.01551 seconds
