Home » Eclipse Projects » Virgo » Virgo JVM not started using -server parameter
Virgo JVM not started using -server parameter [message #937960] Tue, 09 October 2012 08:10 Go to next message
GianMaria Romanato is currently offline GianMaria Romanato
Member
is it intentional that the bash script used for starting Virgo 3.5.0 does not specify the -server parameter to the JVM?
GianMaria.
Re: Virgo JVM not started using -server parameter [message #940341 is a reply to message #937960] Thu, 11 October 2012 10:48 Go to previous message
Glyn Normington is currently offline Glyn Normington
IIRC we experimented with the server VM mode years ago, but there was little, if any, advantage. Feel free to set it in the JAVA_OPTS environment variable.
If you observe any noticeable improvement, please say so!
Previous Topic:<tx:annotation-driven /> not recognized
Next Topic:Spring contexts and aspectj weaver
Current Time: Sun May 19 06:42:30 EDT 2013
Powered by FUDForum. Page generated in 0.04596 seconds
