Home » Eclipse Projects » Eclipse 4 » How to add a view to the Eclipse Platform SDK
How to add a view to the Eclipse Platform SDK [message #937609] Tue, 09 October 2012 01:23 Go to next message
Eclipse User is currently offline Eclipse User
I would like to add a whole new view to the platform (eg Eclispe SDK or
some other distribution). Up to know all the documentation I have found
is about adding fragments to an application (RCP) which has an ID. How
do I add a view to the platform itself? What is the id for the platform?
I will be also using some previously created editor in GMF and my new
view in e4, how do I integrated both? There seems to be some kind of
compatiblity layer and an application xmi for legacy components?
-H
Re: How to add a view to the Eclipse Platform SDK [message #937990 is a reply to message #937609] Tue, 09 October 2012 08:52 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
"add a view to the platform" is a bit ambiguous. Is this a pure e4 RCP? Or a mixed approach with the compatibility layer. If e4 you can add it through the application editor or programmatically. If you use the compatibility layer than the technique should be the same as the 3.x way.
Re: How to add a view to the Eclipse Platform SDK [message #938088 is a reply to message #937990] Tue, 09 October 2012 10:31 Go to previous messageGo to next message
Hugo A. Garcia is currently offline Hugo A. Garcia
Not building an RCP. I want to add a view to the Eclipse SDK,
-H
Re: How to add a view to the Eclipse Platform SDK [message #938093 is a reply to message #938088] Tue, 09 October 2012 10:40 Go to previous messageGo to next message
Then you should use the 3.x mechanisms. Try the RCP or better the plug-in development forum.
Re: How to add a view to the Eclipse Platform SDK [message #938112 is a reply to message #938093] Tue, 09 October 2012 10:53 Go to previous messageGo to next message
so... this means that it is not possible to use e4 mechanisms with the
SDK? If so... is it planned for the next release?
-H
Re: How to add a view to the Eclipse Platform SDK [message #938436 is a reply to message #938112] Tue, 09 October 2012 18:03 Go to previous message
Yes it is planned. The limitations are described in https://bugs.eclipse.org/bugs/show_bug.cgi?id=376486
Previous Topic:Renaming default commands
Next Topic:treeviewer prob,eclipse rcp,juno
Current Time: Tue May 21 04:09:11 EDT 2013
Powered by FUDForum. Page generated in 0.02359 seconds
