Home » Modeling » EMF » Display other properties in EMF tree editor
Display other properties in EMF tree editor [message #936808] Mon, 08 October 2012 07:09 Go to next message
Elhamlaoui Mahmoud is currently offline Elhamlaoui Mahmoud
I try to display other properties instead of than name which the default attribue in the emf based editor, with no success.
Any ideas??
Re: Display other properties in EMF tree editor [message #936826 is a reply to message #936808] Mon, 08 October 2012 07:24 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
What did you try?
On 08/10/2012 1:09 PM, elhamlaoui Mising name wrote:
> Any ideas??
Re: Display other properties in EMF tree editor [message #936916 is a reply to message #936826] Mon, 08 October 2012 09:27 Go to previous messageGo to next message
Hi Ed,
In the tree based editor (TBE) of an ecore model, by default you have the name of the attribute that is diplayed, what i need to do is show on the TBE other elements for my metamodel rather than the name attribue.
sorry for my english
Re: Display other properties in EMF tree editor [message #937079 is a reply to message #936916] Mon, 08 October 2012 12:34 Go to previous messageGo to next message
So it sounds like you haven't tried anything yet...
In the Generator editor you can choose for a GenClass, which feature
will be used as the label. For more complex things, you can modify the
getText method of the generated item provider.
On 08/10/2012 3:27 PM, elhamlaoui Mising name wrote:
> Hi Ed,
Re: Display other properties in EMF tree editor [message #937116 is a reply to message #937079] Mon, 08 October 2012 13:26 Go to previous messageGo to next message
I see, in fact i create the model with the EMF MODEL, an epsilon project. It allows to have a model instance without generating any code. So i think its not possible to solve the problem without generating code. Is that so?
Thanks Ed
Re: Display other properties in EMF tree editor [message #937268 is a reply to message #937116] Mon, 08 October 2012 17:01 Go to previous message
Yes, in that case you only get what the reflective editor gives you,
which are default you can't tailor.
> Thanks Ed
Previous Topic:Writing files to be imported as EMF models...
Next Topic:Serialize only selected objects....
Current Time: Wed May 22 23:22:24 EDT 2013
Powered by FUDForum. Page generated in 0.02455 seconds
