Home » Modeling » Papyrus » Papyrus and attributes' types
Papyrus and attributes' types [message #936220] Sun, 07 October 2012 16:35 Go to next message
Crush Mach is currently offline Crush Mach
I am trying to use Papyrus and Acceleo to generate code. But I am facing a problem with attributes' types. I want to generate a java.util.Date attribute but all I can find is an EDate. Same thing with any other type which is not a primitive type.
Any idea how I can resolve this?
Re: Papyrus and attributes' types [message #936243 is a reply to message #936220] Sun, 07 October 2012 17:09 Go to previous messageGo to next message
The instanceTypeName of EDate is java.util.Date so you may be creating a
problem where none exists.
But since you don't give any details, only you can know.
Ed Willink
On 07/10/2012 21:35, Crush Mach wrote:
Re: Papyrus and attributes' types [message #936279 is a reply to message #936243] Sun, 07 October 2012 18:07 Go to previous messageGo to next message
Thx Ed for your reply,
I understand that. My problem is that I have to generate a specific java code from my class diagram and it has to have Date, Long ...as types, and not EDate
Re: Papyrus and attributes' types [message #936743 is a reply to message #936279] Mon, 08 October 2012 05:35 Go to previous messageGo to next message
So what's the problem? An Acceleo template is very capable of using the
instanceTypeName of an EDataType.
Ed Willink
On 07/10/2012 23:07, Crush Mach wrote:
> Thx Ed for your reply, I understand that. My problem is that I have to
Re: Papyrus and attributes' types [message #938128 is a reply to message #936743] Tue, 09 October 2012 11:15 Go to previous message
Camille Letavernier is currently offline Camille Letavernier
You probably need to define a UML DataType in your model (e.g. create a new DataType named "Date"). Then you use this datatype to type your UML properties.
In your acceleo template, simply generate a java.util.Date object each time you have a property typed with your UML DataType named "Date". Thus, you won't need to use the Ecore EDataType/EDate elements.
Camille
Previous Topic:Relationship of Editors to Resource Sets
Next Topic:Why I cannot create a papyrus project
Current Time: Fri May 24 07:22:49 EDT 2013
Powered by FUDForum. Page generated in 0.05075 seconds
