Home » Eclipse Projects » BIRT » Birt Web Viewer Internationalization
Birt Web Viewer Internationalization [message #551141] Thu, 05 August 2010 08:27 Go to next message
Árisson Leal is currently offline Árisson Leal
I have the birt web viewer deployed with my web app and i want translate all text to the Brazilian portuguese language.
I've put all jars available in the NLpack1-birt-runtime-2_5_0.zip (http://download.eclipse.org/birt/downloads/lang2.5.php) in to the corresponding directories in my web app and i changed the value for the BIRT_VIEWER_LOCALE param to pt_BR, but my birt web viewer still appears in english.
What could be wrong?
Re: Birt Web Viewer Internationalization [message #551202 is a reply to message #551141] Thu, 05 August 2010 11:12 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
What is the locale you are setting?
In that pack I believe it supports
de_DE
es_ES
fr_FR
ja_JP
ko_KR
zh_CN
Jason
On 8/5/2010 8:27 AM, Árisson Leal wrote:
> in english.
Jason Weathersby
BIRT Exchange
Re: Birt Web Viewer Internationalization [message #551235 is a reply to message #551202] Thu, 05 August 2010 13:05 Go to previous messageGo to next message
NLpack1 - Contains the NL fragments and the NL features that contain those fragments for: German, Spanish, French, Italian, Japanese, Korean, Portuguese (Brazil), Traditional Chinese and Simplified Chinese.
I try pt_BR but don't work.
This is the right pack, isn't ?
Re: Birt Web Viewer Internationalization [message #551251 is a reply to message #551235] Thu, 05 August 2010 13:27 Go to previous messageGo to next message
Does not look like its in that pack. Can you try the 2a pack?
Also we are trying to move everything to Babel, so if you look at this link
http://download.eclipse.org/technology/babel/babel_language_ packs/galileo.php
You will find this download
BabelLanguagePack-birt-pt_BR_3.5.0.v20091121043401
If you extract it you can find the viewer properties file for pt_BR:
BabelLanguagePack-birt-pt_BR_3.5.0.v20091121043401\eclipse\p lugins
org.eclipse.birt.report.viewer.nl_pt_BR_3.5.0.v2009112104340 1.jar
Jason
Jason Weathersby
BIRT Exchange
Re: Birt Web Viewer Internationalization [message #551261 is a reply to message #551251] Thu, 05 August 2010 14:20 Go to previous messageGo to next message
Hi Jason,
I tried the BabelLanguagePack-birt-pt_BR_3.5.0.v20091121043401 but still appears in english.
any clue?
Re: Birt Web Viewer Internationalization [message #551458 is a reply to message #551261] Fri, 06 August 2010 10:08 Go to previous messageGo to next message
What I did what extracted the babel language package and copied:
BabelLanguagePack-birt-pt_BR_3.5.0.v20091121043401\eclipse\p lugins\
to
WebViewerExample\WEB-INF\lib
and set my locale on the url to pt_BR and it worked.
Jason
On 8/5/2010 2:20 PM, Árisson Leal wrote:
> Hi Jason,
> appears in english.
> any clue?
Jason Weathersby
BIRT Exchange
Re: Birt Web Viewer Internationalization [message #551462 is a reply to message #551458] Fri, 06 August 2010 10:29 Go to previous messageGo to next message
Hi Jason,
I was doing the wrong way, but now works fine.
Thanks a lot!
Re: Birt Web Viewer Internationalization [message #740377 is a reply to message #551462] Tue, 18 October 2011 08:48 Go to previous messageGo to next message
Ulrich  is currently offline Ulrich
I am stuck with the same problem at BIRT version 3.7.1.
The labels of my own report are adapted to the locale, but the viewer's labels aren't.
What I have done: copied all the jars of the eclipse plugin like org.eclipse.birt.report.viewer.nl_pt_BR_3.7.0.v20110723043401.jar to WEB-INF/lib.
Use __locale parameter, changed language of browser, parameter in web.xml.
Still the labels in the viewer are in English.
Extracted viewer_pt_BR.properties to WEB-INF. However, it does not contain strings like "Showing page". I checked the jsp page for the keys it uses, e.g.
birt.viewer.navbar.lable.goto
Included that with and without "birt." in the extracted viewer_pt_BR.properties.
Still all in English ...
Re: Birt Web Viewer Internationalization [message #740517 is a reply to message #740377] Tue, 18 October 2011 11:43 Go to previous messageGo to next message
Ulrich,
Can you try the one from the galileo package. It seemed to work for me
with 3.7, and none of the labels have changed in the viewer.
http://download.eclipse.org/technology/babel/babel_language_packs/R0.9.0/galileo/galileo.php
Seems like the latest Babel packs do not contain the viewer tags.
Jason
On 10/18/2011 8:48 AM, Ulrich wrote:
> labels aren't.
> WEB-INF/lib.
> it uses, e.g.
> Thanks
Jason Weathersby
BIRT Exchange
Re: Birt Web Viewer Internationalization [message #740528 is a reply to message #740517] Tue, 18 October 2011 11:53 Go to previous messageGo to next message
Eclipse User
18.10.2011 18:43, Jason Weathersby kirjoitti:
> Ulrich,
> Jason
There are lots of zipfiles in that folder for one language. Do they all
need to be added, or only one of them, to get the WebViewer localized?
br
jarif
>> labels aren't.
>> WEB-INF/lib.
>> web.xml.
>> it uses, e.g.
>> Thanks
You have an unusual understanding of the problems of human relationships.
Re: Birt Web Viewer Internationalization [message #740546 is a reply to message #740528] Tue, 18 October 2011 12:16 Go to previous messageGo to next message
Should be this file:
org.eclipse.birt.report.viewer.nl_pt_BR_3.5.0.v20110723105825.jar
Jason
>> Ulrich,
>> Jason
> br
> jarif
>>> Hi,
>>> labels aren't.
>>> WEB-INF/lib.
>>> web.xml.
>>> it uses, e.g.
>>> Thanks
Jason Weathersby
BIRT Exchange
Re: Birt Web Viewer Internationalization [message #740573 is a reply to message #740546] Tue, 18 October 2011 13:00 Go to previous messageGo to next message
Eclipse User
18.10.2011 19:16, Jason Weathersby kirjoitti:
> Jason
I dropped org.eclipse.birt.report.viewer.nl_fi_3.5.0.v20110723105825.jar
to WEB-INF/lib and nothing changed (BIRT 3.7.1 WebViewer)
The report content is in Finnish, but not the Viewer.
>>> Ulrich,
>>> Jason
>> br
>> jarif
>>>> Hi,
>>>> labels aren't.
>>>> WEB-INF/lib.
>>>> web.xml.
>>>> keys
>>>> it uses, e.g.
>>>> Thanks
FORTUNE PROVIDES QUESTIONS FOR THE GREAT ANSWERS: #4
A: Go west, young man, go west!
Q: What do wabbits do when they get tiwed of wunning awound?
Re: Birt Web Viewer Internationalization [message #740637 is a reply to message #740573] Tue, 18 October 2011 14:30 Go to previous messageGo to next message
It looks like the fi jar does not have all the messages in it:
ie BirtResources.getMessage( "birt.viewer.navbar.prompt.one" )
Jason
>> Jason
>>>> Ulrich,
>>>> Jason
>>> br
>>> jarif
>>>>> Hi,
>>>>> labels aren't.
>>>>> WEB-INF/lib.
>>>>> web.xml.
>>>>> keys
>>>>> it uses, e.g.
>>>>> Thanks
Jason Weathersby
BIRT Exchange
Re: Birt Web Viewer Internationalization [message #741713 is a reply to message #740637] Wed, 19 October 2011 16:38 Go to previous messageGo to next message
Thanks for the replies.
At the end I decided to integrate Birt in a more direct way without the viewer.
Re: Birt Web Viewer Internationalization [message #933866 is a reply to message #741713] Fri, 05 October 2012 08:11 Go to previous message
Anthony Farrell is currently offline Anthony Farrell
this worked.
http://www.eclipse.org/forums/index.php/m/933865/#msg_933865
Previous Topic:Integrated BIRT Report giving OCL errors
Next Topic:How to suppress a detail row based on the values from prev. row?
Current Time: Sun May 26 01:26:03 EDT 2013
Powered by FUDForum. Page generated in 0.01947 seconds
