Home » Modeling » Papyrus » broken .di file
broken .di file [message #933678] Fri, 05 October 2012 04:29 Go to next message
Vlad Gheorghe is currently offline Vlad Gheorghe
Member
Using Papyrus 0.9.0 I've run into a situation when the model didn't open anymore.
After some analysis using "sample ecore editor" to load all the model files and running validation, it turns out that only the .di file is broken, while the .uml and .notation files are valid.
My work-around to repair the .di file was to overwrite it with something like:
<?xml version="1.0" encoding="ASCII"?>
<di:SashWindowsMngr xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:di="http://www.eclipse.org/papyrus/0.7.0/sashdi">
  <pageList>
    <availablePage>
      <emfPageIdentifier href="model.notation#_1rtvgAleEeKk1_-gt_aoIA"/>
    </availablePage>
    <availablePage>
      <emfPageIdentifier href="model.notation#_FytBMAlfEeKk1_-gt_aoIA"/>
    </availablePage>
    <availablePage>
      <emfPageIdentifier href="model.notation#_a2GwQAlkEeKk1_-gt_aoIA"/>
    </availablePage>
    <availablePage>
      <emfPageIdentifier href="model.notation#_rChf4AumEeKrv4P5cGyplg"/>
    </availablePage>
    <availablePage>
      <emfPageIdentifier href="model.notation#_853ecAuyEeKrv4P5cGyplg"/>
    </availablePage>
    <availablePage>
      <emfPageIdentifier href="model.notation#_wEjjcAuzEeKrv4P5cGyplg"/>
    </availablePage>
  </pageList>
  <sashModel currentSelection="//@sashModel/@windows.0/@children.0">
    <windows>
      <children xsi:type="di:TabFolder"/>
    </windows>
  </sashModel>
</di:SashWindowsMngr>
And now it seems to work.
Questions:
- Is there a "default" content for the .di file, given a related uml and notation files pair ?
- Is there an automatic repair of the .di file feature ?
Vlad Gheorghe
Re: broken .di file [message #933704 is a reply to message #933678] Fri, 05 October 2012 05:00 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille Letavernier
No. An (almost) empty Di model is valid, but it doesn't allow you to open the existing diagrams. There's probably something to be fixed here.
Not yet
Camille
Re: broken .di file [message #933736 is a reply to message #933704] Fri, 05 October 2012 05:42 Go to previous messageGo to next message
Member
So just to make it sure - if I have two consistent .notation and .uml files and I write the .di file as in the initial post, where there is one <availablePage> element referencing each diagram in the .notation file, I should get a perfectly working Papyrus model.
Right ?
Vlad
[Updated on: Fri, 05 October 2012 05:44]
Report message to a moderator
Re: broken .di file [message #933740 is a reply to message #933736] Fri, 05 October 2012 05:45 Go to previous messageGo to next message
That's right.
Camille
Re: broken .di file [message #933836 is a reply to message #933740] Fri, 05 October 2012 07:41 Go to previous message
Member
Thanks !
Previous Topic:update from juno r to 0.9.1 - no network
Next Topic:Relationship of Editors to Resource Sets
Current Time: Thu May 23 06:52:58 EDT 2013
Powered by FUDForum. Page generated in 0.01560 seconds
