| Adding/removing files from working sets [message #932177] |
Wed, 03 October 2012 18:46  |
Jesse Weinstein Messages: 35 Registered: July 2012 |
Member |
I cannot find a way to add or remove a particular file from a working set without going into the Edit Working Sets, scrolling through the very, very long list of files, and re-selecting the desired file. Is there any way to do this? Has someone written a plugin that adds this functionality?
For reference, I'm using Indigo, mainly with CDT (but I hope this would be general between the various language interfaces).
I also have AnyEdit installed.
| Re: Adding/removing files from working sets [message #932391 is a reply to message #932177] |
Thu, 04 October 2012 00:06   |
Ed Merks Messages: 24540 Registered: July 2009 |
Jesse,
Drag and drop works nicely in the package explore, i.e., dragging a
project onto a working set in the project . You can hold the Ctrl key
down if you want to to add the same project to more than one working set
rather than just move it from one to the other. It looks like the
project explorer doesn't support that, and that's probably what you're
using, unless CDT has a specialized explorer that does...
> functionality?
FUDForum. Page generated in 0.02641 seconds
