| [Acceleo]Using 2 metamodels in combination with 2 separate model instances [message #932663] |
Thu, 04 October 2012 05:59  |
Frederik Gailly Messages: 4 Registered: October 2012 |
Junior Member |
Context:
MM 1: ER metamodel
MM 2: Policy metamodel wich refers to metamodel1 and uses metaconcepts that are defined in MM1
Model1 (model1.er): instantiation of MM 1 which is created using an EMF generated editor
Model 2 (model2.policy): instantiation of MM2 which contains a reference to Model 1 and uses concepts defined in model 1
Problem:
I can define an mtl generation file using Acceleo which contains no syntax errors. However when I run this file there seems to be something wrong when I want to use the references in model2 to elements in model1. Seems like model2 cannot find model1.
Thanks in advance,
Frederik
[Updated on: Thu, 04 October 2012 09:16] Report message to a moderator
FUDForum. Page generated in 0.01716 seconds
