Home » Eclipse Projects » Eclipse RT (runtime) » File too long error (CreateProcess error=206, The filename or extension is too long)
File too long error [message #903247] Wed, 22 August 2012 12:55 Go to next message
raghavan kanagiri is currently offline raghavan kanagiri
Dear,
I am getting the below exception when trying to run ant build script i am getting file name too long exception . I tried to reduce the file name even getting the same exception.
I tried to search but found the this was an existing issue in eclipse.. if the file name is too long then we get this exception and the issue would be solved by changing eclipse plugin .. even that plugin change did not work for me.
the exception i am getting is as below.
Buildfile: C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml
init:
generateJAXB:
[echo] Generating JAXB classes for C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\WebContent\xsd\magiccbxsd\LciTrunkMisceqReply.xsd
[jaxbgen] JAXB generation started.
[xjcTask] Consider using <depends>/<produces> so that XJC won't do unnecessary compilation
[xjcTask] Compiling file:/C:/Users/chalh1/AppData/Local/Temp/jaxb-schema8004715255483005954.xsd
[xjcTask] removing old output files
[xjcTask] Writing output to C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\src
[jaxbgen] JAXB generation ended.
compileJAXB:
[javac] C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml:67: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 11 source files to C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\build\classes
22-Aug-2012 9:17:06 AM com.legstar.codegen.tasks.CommonsLoggingListener taskFinished
WARNING:
ARNING:
iadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml:67: Error running C:\TriadWorkspace\jdk1.6.0_31\bin\javac.exe compiler
at org.apache.tools.ant.taskdefs.compilers.DefaultCompilerAdapter.executeExternalCompile(DefaultCompilerAdapter.java:525)
at org.apache.tools.ant.taskdefs.compilers.JavacExternal.execute(JavacExternal.java:61)
at org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:1134)
at org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:912)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:390)
at org.apache.tools.ant.Target.performTasks(Target.java:411)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.eclipse.ant.internal.launching.remote.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.eclipse.ant.internal.launching.remote.InternalAntRunner.run(InternalAntRunner.java:424)
at org.eclipse.ant.internal.launching.remote.InternalAntRunner.main(InternalAntRunner.java:138)
Caused by: java.io.IOException: Cannot run program "C:\TriadWorkspace\jdk1.6.0_31\bin\javac.exe": CreateProcess error=206, The filename or extension is too long
at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
at java.lang.Runtime.exec(Runtime.java:593)
at org.apache.tools.ant.taskdefs.Execute$Java13CommandLauncher.exec(Execute.java:862)
at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:481)
at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:495)
at org.apache.tools.ant.taskdefs.compilers.DefaultCompilerAdapter.executeExternalCompile(DefaultCompilerAdapter.java:522)
... 19 more
Caused by: java.io.IOException: CreateProcess error=206, The filename or extension is too long
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(ProcessImpl.java:81)
at java.lang.ProcessImpl.start(ProcessImpl.java:30)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
... 24 more
22-Aug-2012 9:17:06 AM com.legstar.codegen.tasks.CommonsLoggingListener targetFinished
ARNING: 22-Aug-2012 9:17:06 AM com.legstar.codegen.tasks.CommonsLoggingListener targetFinished
nished
... 19 more
... 24 more
BUILD FAILED
C:\TriadWorkspace\P4Dev\eclipse\workspace\phase4\triadWs\ant\build-coxb-LciTrunkMisceqReply.xsd.xml:67: Error running C:\TriadWorkspace\jdk1.6.0_31\bin\javac.exe compiler
Re: File too long error [message #930263 is a reply to message #903247] Tue, 02 October 2012 02:44 Go to previous messageGo to next message
nelson 32 is currently offline nelson 32
Long Path Tool helped me in this situation. www.PathTooDeep.com
[Updated on: Tue, 02 October 2012 02:45]
Report message to a moderator
Re: File too long error [message #930756 is a reply to message #903247] Tue, 02 October 2012 12:01 Go to previous messageGo to next message
Alisa Bin is currently offline Alisa Bin
hello friends Long Path Tool helped me in this situation. www.PathTooDeep.com
visit here for collect more information.
Re: File too long error [message #934508 is a reply to message #903247] Fri, 05 October 2012 22:36 Go to previous messageGo to next message
Hello friend, I have same problem of you, but Long Path Tool helped me in this situation. www.PathTooDeep.com. Visit here for more information. If your problem is not solution, OK meet with me on Skype: saifbd3344. Thank you so much.
Re: File too long error [message #941414 is a reply to message #934508] Fri, 12 October 2012 09:54 Go to previous messageGo to next message
Neelson 32 is currently offline Neelson 32
Long Path Tool helped me in this situation. pathtoodeep.com
Re: File too long error [message #941491 is a reply to message #903247] Fri, 12 October 2012 11:23 Go to previous messageGo to next message
rowin das is currently offline rowin das
Long Path Tool helped me in this situation, so at lest you can download a latest version of "Long Path Tool" for able to delete, remove, renaming and others solve. Thanks.
Re: File too long error [message #943475 is a reply to message #941491] Sun, 14 October 2012 10:50 Go to previous messageGo to next message
No Message Body
Re: File too long error [message #954904 is a reply to message #903247] Tue, 23 October 2012 06:45 Go to previous messageGo to next message
arw inis is currently offline arw inis
Path too long/ deep.....? Please look that, LONG PATH Error Fixer helped me in this situation. Actually "Long Path Tool" is so usefully for this problem. So try it today.
Re: File too long error [message #978792 is a reply to message #903247] Sat, 10 November 2012 05:29 Go to previous message
Gabriel Nar is currently offline Gabriel Nar
PathTooDeep.com
Previous Topic:OSGi complaint
Next Topic:Workbench Persistence question
Current Time: Thu May 23 23:59:14 EDT 2013
Powered by FUDForum. Page generated in 0.01796 seconds
