Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Generating TypeConverter puts quotes around classes
[Texo] Generating TypeConverter puts quotes around classes [message #930683] Tue, 02 October 2012 10:37 Go to next message
Chris Boerger is currently offline Chris Boerger
I'm currently playing around with Texo to determine if I can use it for my project at work.
I've created in the ORM annotations model a TypeConverter annotation to convert from a Duration to a Long. But when Texo generates the JPA annotations it puts quotes around the class names which causes a compile error.
I then have to go remove the quotes to get it to compile, but then I either have to freeze the code (@generated NOT) or remove the quotes every time I make a change to the ecore model which, since I'm playing around right now, is quite often.
Is this a bug or am I not putting the class names in the orm annotation correctly?
Thanks!
Re: [Texo] Generating TypeConverter puts quotes around classes [message #930755 is a reply to message #930683] Tue, 02 October 2012 11:56 Go to previous message
Martin Taal is currently offline Martin Taal
Hi Chris,
Probably this is a bug, class names are handled specifically in Texo because (as you noticed) they are not strings but
should be fully qualified to real classes.
Can you create a bugzilla and attach an example model/annotations model for me?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT&component=Texo&version=0.5
It seems like something I can solve in a day or so.
gr. Martiin
> Thanks!
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Previous Topic:(later) undo "delete from diagram"
Next Topic:EMFStore browser to configure server port/ip
Current Time: Mon May 20 02:23:28 EDT 2013
Powered by FUDForum. Page generated in 0.01451 seconds
