| JWS application On Eclipse 4 - ModelServiceImpl init error [message #930587] |
Tue, 02 October 2012 09:05 |
cenk Mising name Messages: 89 Registered: July 2009 |
Member |
I have exported the feature project to create JNLP application.
But when I start the JNLP file, downloaded all file but not started. I see in configuration/log file that,
!SESSION 2012-10-02 15:53:52.691 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_02
!ENTRY org.eclipse.osgi 4 0 2012-10-02 15:53:53.467
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:92)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:442)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:182)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:554)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at zzz.pronit.test01.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.WebStartMain.basicRun(WebStartMain.java:79)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.WebStartMain.main(WebStartMain.java:57)
at com.sun.javaws.Launcher.executeApplication(Unknown Source)
at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
at com.sun.javaws.Launcher.doLaunchApp(Unknown Source)
at com.sun.javaws.Launcher.run(Unknown Source)
at java.lang.Thread.run(Thread.java:722)
I cant understand that what the problem is?
FUDForum. Page generated in 0.04527 seconds
